Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Just got spinscrub this afternoon and worked great until had to empty dirty water. Now there is no suction at all. Have tried to find clogs and nothing to be found. Am about to return the damn thing!!!
    Novelist:
  • 147 Answers
Ok 3 things to check before re-boxing it up.
1) make sure that the lid is on properly. it should go on with the 2 tabs at the front of the machine, then click into place at the back of the machine.
2) when you emptied it, sometimes the dirt channel will fall out. This allows for the suction to go between the dirty tank and the clear channel for the water to be sucked back up.
3) when you remove the dirty water tank again, look down inside the machine for a circular hole. there should be a rubber gasket on it to seal up the tank for your suction. If it has come loose or is missing, retrace your steps between the machine where it was last used and the sink or wherever you dumped out the dirty water.
Good luck,
Mark
Posted on Nov 11, 2010
Carpet cleaner will not dispense water
Keep pressing the water button to primer the water through the hose
Aug 05, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The suction is not working. we have tried all the
check RECOVERY TANK LID and DUCT
May be the duct is off the hook
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover SteamVac has been doing a wonderful job but in two instances, after emptying the dirty water and reattaching the reservoir, the machine has lost suction. The first time I was able to make it work...
look for the lower tank filter to be clean. also make sure the lower tank lid is on properly. latch when installed on machine. Make sure the front panel duct is on the lower tank.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover spinscrub 800. It washes great
in some cases when this happenes it's usually from a really bad filter or the squeege at the bottom of the nozzle. the squeege is what makes contact with the floor and suctions all of the water up. to take off. take off the nozzle and there will be (3) screws inside of the nozzle. once these screw are removed, the squeege can be removed. at hoover.com the replacement part # is 93001094. ( according to model # H3060 )
Jul 31, 2009 | Hoover H3060 FloorMate SpinScrub 800...
Won't **** up water
your suction channel is clogged.look on the top of the base cover right up the middle.thats where all the dirt and hair goes before it gets to the dirty water tank.it probably clogged.there are some screws on the bottom that you need to take out to remove the cover.once you get the cover it will seperate into 2 pieces.which allows you to clean the suction channelplease leave feedback if i've been some help to you
Apr 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
No Suction
Possible Causes Remedies
Tank is full. Empty tank.
Dirty/Collection tank latch is not down. Push latch down, securely
into place.
Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
Usually there is a seal out of place, or a filter is clogged, so you lose suction.
Apr 30, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
77 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
