Question about Keurig Platinum B70 Coffee Maker
Started going off and now won't come on at all.
  • 5 more comments
  • dkward Nov 11, 2010
    does not come on at all
    Yes, it is dead.
    Thanks
    I cleaned it with vinegar not long ago. It started shutting itself off but would come back on if I hit the switch. This morning it did it again but would not come back on.
  • dkward Nov 12, 2010
    My Keurig B70 started shutting itself off and after brewing 1 cup of coffee this morning it would not come back on at all. It's dead.
  • dkward Nov 13, 2010
    Thanks for the help, but that's not it. Can't check to see if the automatic shut-off is enabled because it won't come on. If you have any other ideas please let me know.
  • dkward Nov 14, 2010
    Our B70 Keurig died. It started shutting itself off and now it won't come on at all. We've checked everything we know. Could the off/on switch be bad? If so, can it be fixed?
  • dkward Nov 16, 2010
    Thanks. I'll sure try it. I've already sent them an e-mail but haven't heard yet. I'll let you know how it turns out. Thanks again for your help.
  • 3,083 Answers
Another person on Amazon reported this problem, and Keurig sent them a new one:
By Firefighter ***** "FF *****" (Fairfax, VA USA) - See all my reviews
Amazon Verified Purchase(What's this?) This review is from: Keurig B-40 B40 Elite Gourmet Single-Cup Home-Brewing System (Kitchen) You're probably wondering why I would give 5 stars to a product that broke on me in the first six months. Well, let me tell ya...
I bought the B-40 Elite through Amazon in January 2010 and used it daily for about three months until our weather warmed up here. I'm not a huge fan of coffee in the summer, so my machine got a rest. But twice in the past couple of months I've fired it up and it won't start. The power comes on, it hisses for a few minutes, then shuts off. The water never heats up.
So I called the Customer Service Line yesterday and they walked me through a couple of potential fixes and then, out of nowhere, the technician says, "Ok, I'll send you a new one. All you have to do is send me back the K-Cup holder (which is a tiny plastic cup about the size of two shot glasses)."
"That's it? Really?"
"That's it. No charge. Just put the little plastic K-Cup holder into a padded envelope and send it back to me within 30 days. And for your trouble, I'm going to send you some extra coffee. What kinds are your favorites?"
Wow. Talk about bowled over. While I love my B-40 Elite and my coffee (try Donut Shoppe), I love their customer service even more.
Here's their web support site:
http://www.keurig.com/customer-service
Contact them, or whoever you purchased it from, and perhaps you will have the same luck.
Hope this helps!
Posted on Nov 14, 2010
    President:
  • 2,923 Answers
Unfortunately this is a common problem. The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists.
You also need to check if the auto-shut off is enabled. If it's enabled, try to turn it off and see if that will help.
Thank you and good luck!
Posted on Nov 12, 2010
  • 10,515 Answers
Kindly clarify whether it does not brew or it does not on at all (dead)?
Thanks!!
Posted on Nov 11, 2010
My Baumatic larder fridge won't go cold the fan and the compressor is working but the temp won't go below 16 degrees
Check to see if there is ice built up around the door preventing it from closing and sealing properly. This can happen if the door isn't closed all the way at times.
Jan 26, 2013 | Refrigerators
Won't go in gear when car started
If it's a clutch,check clutch master fluid,if real low or out,go check clutch slave cylinder,it's bolted on side of transmission,see if it is leaking,if so replace and bleed.You can fix temporary,fill reservoir and bleed,will get you there,done it.
Oct 27, 2012 | ACT Clutch Disc for 1999 - 2001 Nissan...
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
My 1998 dodge stratus needs to be jump started everyday, what could be the problem
Need to get a meter on that car,auto zone will do it,make sure it's charging.
I am thinking the voltage regulator is not in the alternator.Think it's in the control computer. If it goes bad ,the car won't charge.Instead of buying a computer you can also use an older style (say 1980's) external electronic regulator.have to get a pigtail from a parts store ,hook up 2 wires to the alt. Cap and seal the old wires that used to go to the ECM. Works fine and won't go bad again.
Jan 26, 2012 | 1998 Dodge Stratus
Won't stay started for me, first time scooter owner too, got it started but when I go to give it the gas, it just sputters out!
sound like carb problem. Not getting any fuel. check fuel line and filter. if that doest work, take carb of and clean...
Oct 09, 2011 | 2008 Qlink Siena 150
Factory alarm started acting up a few days ago, now car won't start. only hear single click noise. managed to jump started it once
Could be the battery is dead or dieing. When batteries start to go they will cause the security to act up. Plus other things
Aug 08, 2011 | 2006 Hyundai Tiburon
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
