Question about Makita Drills
I have a new 7000 battery for my 6075D Makita drill. The drill won't turn at all. battery is charged. I wanted to take the drill casing apart. All the screws are out. the casing will not come apart near the front of the drill. afraid to break it. any pointers? Thanks Rick
  • 863 Answers
Makita engineers are sneaky bastards that's why. There's a special tool required to take the front off and another compression tool to compress all the parts back together. You got to find your local Makita service center and have them do it. They make these Makitas like Hondas, because they want to keep all the money and don't want you monkeying around and fixing the parts yourself for cheap.
I know, I know life's a b.tch sometimes.
Posted on Nov 11, 2010
Testimonial: "This was very helpful even though it was somewhat bad news. It saved me from doing permanent damage and a load of frustration. Thankyou Rick "
Rebuilding makita battery instructions
Rechargeable batteries are almost never worth rebuilding and never last very long when they are. In some cases, Makita being one, if the circuit board in the battery detects something wrong with the battery, it 'bricks' the battery. This is not resettable and the battery will not charge on a Makita charger. I'd be looking to get my money back from the repairman since his rebuild didn't take.
Jan 16, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita battery won,t charge
Return it to the place of purchase if under a year or send it to Makita UK in Milton Keynes
Dec 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
Jun 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 1822 battery not holding charge
If the Makita battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jan 21, 2012 | Drills
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My 24v new makita drill doesnt hold charge
the new batteries now have a little computer in them, so to speak. when you plug in the battery to the charger and you get the alternate flashing light the battery is bad. if the charger is working and the battery is just not lasting very long the battery may be going bad. there could be a problem in the motor causing your battery to drain too fast. does the drill work normal, no overheating or noise, bad bearing.
Apr 18, 2010 | Makita 6408K 3/8" Variable Speed,...
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drills Logo
214 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
