Question about MSI Computers & Internet
Laptop keyboard has stopped working, tried to reboot still didn't work, i have my printer, mouse and memory stick connected to the laptop, i have only had the laptop for about 3 months. It is a MSI laptop.
Hopefully ur warranty is still good on your laptop, if so you could have MSI send you a new keyboard-replacing it is not as hard as you think...just a couple of screws holding it down.
Posted on Jun 17, 2008
Hewlett packard manual
Have you put the battery back in the laptop? Your laptop probably just needs charged. When it blinks it means it needs charged. Is the battery in the laptop correctly? Try putting it on charge. Hope this helps.
- Nathan
Jan 16, 2014 | Computers & Internet
Unable to connect my logitech wireless keyboard to my toshiba laptop please advice
What happens when you try to connect it to your laptop? It just does not work? Have you checked the batteries? When you connect the keyboard to the laptop, you have to reboot before it will work. You also need to calibrate the keyboard - receiver and mouse (if your model came with a wireless mouse). Do you know how to calibrate the system? You press and hold the button on the receiver that is plugged into the pc's usb port, and the button on the back of the keyboard near the battery area, and the button on the bottom of the mouse ALL AT THE SAME TIME for 20 - 30 seconds. That means you press and hold all three buttons at the same time.
that should make it work.
Jul 12, 2011 | Logitech Cordless Desktop Ex100
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
Hi i have an external HD...Seagate FreeAgent GoFlex 1 TB...it is working smoothly on my laptop and other computers..however as soon as i want to connect it to my desktop, it is not being detected. My...
Connect some other USB device (keyboard? mouse? memory-stick?) to your desktop?
Are those devices detected? If not, then either:
* the USB port(s) on your desktop are damaged,
* the device-drivers for the USB ports on your desktop are not installed.
Try connecting it to a different desktop/laptop, to see if the Seagate works at all, on any desktop.
Mar 17, 2011 | Computers & Internet
My ccd-u mouse has stopped working.mouse came with floppy disc so can,t down load driver to my laptop, it was working ok but then stopped thanks
FInd a computer with a floppy-drive and a USB port.
Insert the diskette, and copy all the files to a USB memory-stick connected into the USB--port.
Move the USB memory-stick to your laptop, and connect it.
Access the device-drivers on that device.
Nov 21, 2010 | Computers & Internet
I am plugging the stick into my office laptop. There doesn't seem to be a connection with the stick and the mouse.
First off make sure you have fresh batteries in the mouse. If the batteries are missing or weak then that would cause the no connection between the mouse and the usb stick.
After you check the mouse out for fresh batteries, then go ahead and plug the usb stick into your laptop. At this point you should hear a sound and windows should install the drivers for that mouse, if it doesn't then the next thing would be to try another computer or laptop that has working usb ports and try to connect the usb stick on another computer.
If it works then that means there is an issue with the usb ports on your office laptop. If the mouse still doesn't work then that means the usb stick is bad and you would need to buy a new mouse.
Sep 30, 2010 | Wenger DAYTONA II Mouse
All of a sudden one day, non of the 3 USB ports on my Toshiba #A135-S2276 notebook works anymore. When I plug in a memory stick or a printer, It will show error message as "One of the USB devices...
Try disconnecting all external devices and reboot your laptop.
You must have all USB devices disconnected, memory stick, USB mouse or keyboard, Hard drives, flash cards ect.
After a reboot check your device manager for flags or exclamation marks and remove if present.
Again, re-boot your laptop and check your device manager.
Ounce you have cleared all marks from device manager and all is clear,
plugin your first USB device and check operation.
Please check your equipment manual for details on what USB ports and speeds are available for your required devices.
Hope this works for you.
Please rate ASAP
Thanks
Dec 31, 2009 | Office Equipment & Supplies
My keyboard and mouse stopped working. Changed
disconnect it and try them with the laptop and see if it will work,then later reconnect it again and see.
Dec 14, 2009 | HP xb3000 (417329-001) Docking Station
Keyboard sticks .and also the mouse will jump into another
hi friend,
Erratic Mouse
  1. The solution for an erratic mouse involves going into the registry on Windows. Backup your registry files. Never make changes to the registry without doing this. Go back into the registry. Go to the editor. Locate the key phrase that reads: hkcu---control panel---mouse. Delete this line from the registry. Close the registry editor. Shut down your laptop. Wait for 5 minutes. Reboot your laptop. Windows will create a new registry key for you. This should solve any erratic mouse problems.
  2. Mouse Not Found on Laptop Boot Up
  3. The laptop mouse is plugged in. You boot up your PC. The mouse isn't found. Chances are the mouse cable came slightly unplugged. Unplug the mouse. Re-plug the mouse into the laptop port. The laptop should recognize the mouse. Reboot the laptop if it is still not working after you check the cable.
  4. Mouse Moving Slowly
  5. A laptop mouse that is moving slowly is probably dirty. This type of equipment is prone to collecting dust and dirt. It's like a magnet for dirt. The solution is to clean the laptop mouse. Unplug the laptop mouse from the computer. Remove dirt particles from the optical mouse with a pair of tweezers. Make certain the eye area is clear. A small piece of debris can cause an optical mouse to move slowly. Remove the ball from the mouse, for a standard mouse. Wipe the ball with rubbing alcohol. Wipe the inside of the mouse with a dry cotton swab. Remove all debris and dirt. Replace the ball.
  6. General Mouse Tips
  7. Clean the work area where you will use your laptop mouse. This will reduce the amount of dirt that collects in the mouse.
    Work in areas that don't have high traffic for pets. Sitting with your pet cat or dog in your lap and using your laptop is not a good idea. The laptop mouse will attract and catch pet hair and dander, requiring you to clean it more frequently.
    Wash your hands prior to using your laptop or your laptop mouse. This will keep the equipment cleaner to make it last longer. Less maintenance will be required for both the laptop and the laptop mouse.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); instructions for sticky keyboard: Step 1 Soak up spills immediately after they occur. This not only reduces the risk of damage, it prevents much of the fluid from spreading beneath the keys. Use a towel, cloth or anything else you have handy at the moment.
  • Step 2 Unplug the keyboard from the computer or disconnect the power supply if you are using a laptop keyboard. Make certain nothing else is connected to the keyboard and unplug any USB devices.
  • Step 3 Pop the keys off your keyboard using a dull knife or flathead screwdriver. Do this slowly and carefully to avoid damaging the keys or the keyboard.
  • Step 4 Place the keys in a bowl full of warm soapy water, and let them soak for 20 to 30 minutes. Dish detergent is effective at removing dirt, oil and stickiness.
  • Step 5 Use a damp, lint-free cloth to wipe the large areas of the keyboard. A cotton swab can be used in smaller spaces and around the edge of the keyboard.
  • Step 6 Set the keyboard aside, upside down, on a towel and leave it to dry for several hours. This will also allow any trapped fluid inside the keyboard to drain out.
  • Step 7 Wash off any remaining dirt, oil or debris from the keys. Use a cotton swab to clean inside of each key, if necessary. Rinse the keys very well with warm water and set them on a towel to dry.
  • Step 8 Replace the keys once the keyboard and keys are fully dry. If your keyboard is still sticky, fluid likely leaked deep inside the keyboard. You can attempt to clean the internal part of the keyboard by yourself, but this will void the warranty and risk further damage. Either purchase a new keyboard or send yours to the manufacturer for repair.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Using a can of pressurized air to clean your keyboard will remove any loose dirt and debris but will not get rid of stickiness or oil residue. Take a photo of your keyboard before removing the keys to make replacement easier.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Computers & Internet
    Keyboard not responding
    Boot in safe mode
    >control panel
    >Printers and other hardware
    >Keyboard
    >check to see if is has been disabled
    ??>does you mouse pad work
    >If no plu a USB mouse in 1st before you boot into safe mode
    Aug 28, 2008 | HP Compaq nx6110 PC Laptop
    Computers & Internet Logo
    394 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
