Question about Makita Garden
Motor rev up has no blowing power makita 4-stoke BB 7600 back pack
  • 1,040 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Nov 13, 2010
Keeps blowing internal breaker
The unit rated at 3 HP at 115 volts draws 13.8 amps is odd, a HP in watts is 745 and should be about 2200 watts and 19 amps plus a efficiency loss. Odd to see the ratings don't jive with electric theory/formulas.
The compressor should be connected directly to the wall and if using an extension cord, the cord needs to be #12 AWG or larger to avoid line voltage loss and over amping of the motor.
Here is contact and support info: For more information, please call 800/4-MAKITA (800/462-5482) or visit makitatools.com.
My bottom line is, A 115V motor circuit needs 10 amperes per horse power or 30 amp circuit for 3 horse power. Using extension cords calls for upgrade in wire gage of the cord. The advantage of using 230 volts is it cuts the amperes in half and allows use of smaller gage wire. Watts, or volt amperes is the product of volts and amps.
May 18, 2015 | Makita MAC5200 3.0 HP Air Compressor
When I press the power switch it starts to work at maximum rpm
The variable speed function is controlled by the switch. On rare occasions you can remove the switch, spray it with electronics cleaner and blow it out well to get it to work again. Usually you have to replace the switch. The switch for your impact driver is Makita part number 638326-6 and runs about $65.
Jun 08, 2012 | Makita 6980FDWDE 12V Cordless Impact...
Makita battery drill - batteries have charge, cleaned contacts - no action . Ideas?
Makita switches can go bad along with the electric motors inside ,I would check your battery with a volt meter then split the case and check for power going from battery to switch and forward/rev switch to motor, youmight just find a bad wire connection if you are lucky
Sep 17, 2011 | Garden
2001 polaris sportsman 90 is this a 2 stroke or 4 stroke
It's a two stroke, it has a separate spot to put the two cycle oil under the seat. It injects the oil itself, so you just make sure its always has two cycle oil in there and fill the gas tank with straight gas.
Dec 24, 2010 | Polaris ATV
New makita chainsaw difficult to start. Any suggestions?
sue fresh 2 stoke fuel and buy a new spark plug
Aug 05, 2009 | Makita Garden
Blown engine
makita likes you to use at least 91 octane fuel and a synthetic oil mixture. the stens oils is garbage, i switched to the makita oil around 6 months ago and i havent had a problem. also, the wacker saws use the same motor and their piston heads are sleeved in carbon so they last longer and dont score the cylinder as fast as the stock makita heads.
makita also makes a 100:1 mix hi performance oil you can use.
Oct 30, 2008 | Makita DPC8112 16" 81CC Gas Powered Power...
Garden Logo
217 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
