How to install an ata ide hard drive - Computers & Internet
  • 4,338 Answers
See this link for installing an IDE hard drive:
http://freepctech.com/pc/001/installing_ide_devices.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2010
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Can I install a hard drive in an HP Pavilion 6736 which has a capacity greater than 20GB ? If so, is there an upper limit to the capacity..can I install a 120 GB drive?
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
May 04, 2010 | HP Pavilion 6736 PC Desktop
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Added ide hd and can't boot from ata hd now!
Ah, ok. According to the manual, on page 1-23...here's what you need to do.
According to this page, you need to set onboard ide operate mode to "Enchanced Mode", and Enchanged mode support on to "Sata".
Sep 17, 2008 | ASUS P4P800S Motherboard
WHICH HARD DRIVE INTERFACE IS INSTALLED IN THE 2170US?
Probably just need to pull the Interface block off the old hard drive and install it to the new.. Look close...IDE is IDE but they dont come with the connectors preinstalled.. Good luck!...
Feb 14, 2008 | Compaq Presario 2170US Notebook
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Installing a ata hard disk.
I dont quite get how you've got them connected so I'll tell you how I'd do it.
First of all, it is kind of standard to put the primary drive at the end of the cable but it doesnt really matter. I go with what ever physically works best.
Connect your 2 IDE devices to the same IDE channel (cable) unless you have 2 IDE channels then put each on their own channel or cable. Make sure you are using 60 conductor cables for each.
If both are on the same cable:
Set the dvd's jumper to slave.
Set the hard drive jumper to master
OR
vice versa.
*Some DVD burners do not like to be slave, or even on the same channel as another device.
The following is the ideal set up
If each is on their own channel (cable):
Set each to master
Be sure bios is set to auto detect for all channels, master & slaves.
** If this doesnt resolve your problem, please post a comment before rating.
Oct 17, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Ide and sata hard drives
you need a converter http://www.cooldrives.com/ide-to-sata.html
Oct 05, 2007 | Soltek SL-75FRN2-RL Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
