Question about Bosch Dishwashers
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working again for a further 2 washes. Now when switched on the pump for pumping out the water works continuously. Reset it time seem to count down but does not do anything reset time goes to 0 and beeps but still the pump runs even with the door open. all buttons seem to work fine but no washing and pump won't switch off. Can you advise which part you think has failed.
  • jonathan91 Nov 12, 2010
    I can not find the float switch as described.
    Here is the link to the bosch web site of the components of my dishwasher. http://www.bosch-eshop.com/eshop(bD1lbiZ...
    Thanks for the reply
    I had done what you have suggested and a small amount of water came out over the floor.
    I presume that means there is a leak some ware and the water is sitting in the bottom of the machine and a sensor/trigger is picking that up and causing my problem.
    It looks like I need to take the panels off and find the leak.
    I have done this on several Dishwasher in the parts so it should not be to much of a problem.
    Top comes off easily but which order should I remove other panels.
    President:
  • 1,140 Answers
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Posted on Nov 11, 2010
  • 10 more comments
  • DILLIGAF
    DILLIGAF Nov 12, 2010
    OK, then you're going to need to pull the washer out from under the counter. It's easier and safer if you have someone help you with this next test. Firstly, turn the power off and begin pulling the washer out from under the counter. It may be necessary to unplug the power cable, and disconnect the water supply and drain hose - depending on how much slack is available on each. Once you have removed the washer, put some old towels (or similar) on the floor at the back of the washer and make sure they are tucked in under the washer as far as possible. Next, tilt the washer BACKWARDS slowly about to about 15-20 degrees from vertical. Ideally, there should be one of you on each side of the washer to do this as they are fairly heavy and awkward to support. If water can be seen coming from the bottom of the washer, then you have a leak. Finish draining water from the bottom of the washer by tilting it a little further until no more water appears from under the washer. If you have a leak, there are several possible causes (some simple) but you should do this test and post back here with the results for further assistance. I'm up on a customer's roof this afternoon, refitting a Sky dish that came down in the wind last night, but I will check back regularly for your post. BElectric
  • DILLIGAF
    OK - how much water are we talking about roughly? If it's say, half a cup, that's probably not enough to activate the anti-flood protection which is what seems to have happened to your washer. Before you put the dishwasher back (it doesn't matter if you've already done so), make sure you've drained all the water from under the wash compartment. Next, remove the salt compartment cap. Under the cap is a large plastic nut which secures the salt compartment to the washer. If this nut is loose, this will cause a leak into the bottom of the washer. If it can be unscrewed by hand, it's definitely too loose but try tightening it anyway using a pair of water-pump pliers or Stilson. Don't overtighten though, as it's only plastic and will break! Next, reconnect any hoses/cables you disconnected and try switching it on again and see what happens. Please note, the first part of ANY wash cycle in your Bosch runs the pump to remove any residual water from the machine before starting a wash. This should only run for about 10-20 seconds. Try this and report back. Please be aware that this thread is getting quite long and future messages may soon be on a second page. If you scroll to the bottom of the last visible message, you will see a link to "view all messages".
  • DILLIGAF
    If you are going to take the washer apart, you only need to remove the panel on the right side of the washer when facing the door. This will allow you to see under the washer, but a torch/portable lamp would also be useful. You only have a minor leak so a good way of trying to identify the cause would be to run a wash program while checking under the washer. Check the salt compartment nut first though! There is still the possibility that your fault is in the control module and the leak is too small to cause a problem, but we'll get to that . . .
    It has just done a full cycle without any problems.
    I have checked the salt container and the washer and nut seem fine so I don’t think the problem is there.
    I will see how it goes on the next couple of days and then post back.
  • DILLIGAF
    Good to hear it's running again. This means there is no control module fault, but there is definitely a leak which is activating the anti-flood protection. The severity of the leak can be determined by how long it takes before the problem returns, but don't forget that a small leak can quickly become a large one, so I would advise further investigation when possible. I check messages several times a day, so please post back if/when the problem returns and you need further assistance. BElectric
    Thanks for all your help
    Very busy over the weekend as we have 2 young children and they take up a lot of my time, so shall not get a chance to look at it until next week probably Tuesday or Wednesday.
    Will keep you informed what I have found.
  • jonathan91 Nov 19, 2010
    Did not get a chance to take the side off the machine earlier this week, but had been working fine that is until last night. We set it to come on about 5am at 1am our fuse box tripped out the RCD. It was the dishwasher.
    I have today removed the right hand side cover and yes there is water in the bottom, around the pump there is some lose corrosion, I think it is where it attaches to the plastic section.
    I need to get access to every thing underneath and then remove the pump etc.
    Please can you advise in what order I should do this.
  • DILLIGAF
    DILLIGAF Nov 19, 2010
    Hi Jonathan. Just got your message. From your description, I think you're talking about corrosion around the recycling outflow from the pump - the waste hose attachment to the pump isn't visible with the right side panel removed. Therefore, I have to inform you that repairs related to the pump are the most awkward on the washer and I DON'T recommend this as a DIY fix. However, I realise that you are probably going to attempt it, so I will assist you in getting access to the pump area, but I recommend you try to obtain a service manual first and I accept no responsibility for any damage or costs resulting from this repair. Access to the pump for servicing/removal can only be done from the bottom of the washer, but before doing this, you should do the following: [1] Re-attach the right panel (for rigidity) and drain the water from the bottom of the washer by tilting backwards as before. [2] Remove the right panel again and run a wash cycle while inspecting under the washer to confirm the source of the leak. If you are CERTAIN you know where the leak is coming from, you can skip this. [3] Re-attach the right panel and disconnect the power and water supply. [4] Lie the washer on it's left side when facing the door - I recommend you get someone to help you with this as the bottom of the washer can slip out when it's tilted. [5] Remove the screws around the edges of the underside steel panel and remove it. I think it's a T20 Torx/T-Star screwdriver to remove these screws, but I assume you've got one as you've already removed the right panel. The float may drop out when you remove the underside, but this can simply be slotted back in before re-attaching the underside. You should now have access to the pump area. You can also remove the right panel again if you need access from that side (it should now be facing upwards!) but you should leave this in place whenever possible to maintain rigidity of the unit. The kick plate under the door can also be removed if required - there are 2 (T20) screws at the front which are only visible with the door folded down, but it's easier to remove this when the washer is upright. Removing the kick plate doesn't really give much better access, so I would leave it on unless you absolutely need to remove it. That's about all I can help you with at the moment, but I will checking messages regularly for the rest of the evening and all weekend so post back whenever. Also, if you need parts, I recommendhttp://www.ukwhitegoods.co.uk as they have good stock, deliver quickly and are very helpful if you have any queries about parts or are unsure which parts you need. Good luck! Regards, BElectric
    Thank you for you answer.
    The bottom panel is solid plasic with no removale sections.
    I beleve I have to loosen and remove the right hand screws from the Stainless stee container and plasicbase and raise the right hand side of the container upwards about 4cm to get enough access to the pump. Then press the catch to the right side of the circulation pump and rotate the pum to remove it. The replace the seals.
    The only dificulty I ever have with diswashers is in which order and what I need to re move to get access to the faulty parts. Rather then strip them down completly.
  • DILLIGAF
    Sorry, I didn't intend to imply you weren't capable. If I really thought that, I would have simply said "get an engineer" and offered no information. Having read your description above, I cannot recall having worked on that particular Bosch model anyway so I can't offer any more specific advice on your repair but I'm willing to answer any general queries you have. You can also refer to previous posts on FixYa related to this model and the forum section of the supplier I recommended above is very useful.
    Thanks for all your help it is much appreciated. Will let you know how I get on.
Bosch dishwasher growling and not draining
Bosh dishwashers work off a gravity pump system. They sometimes require a stronger pump. Make sure if it has a air gap either at the top of the sink or johnston T or in the wall that, that is not plugged. They are very sensitive to how the drainelines are set as well. If it was installed prfessionally, call the installer back out as they should warranty there install for 1 year. Also all products have a 1 year MF warranty as well. You should be able to get a BOSH tech out at NO charge to see if it is a deffective pump.
May 04, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Water pump works from the minute I press the main switch
I may have had the same problem. At the end of a normal wash cycle the pump would stay on for hours or even days - I would have to power off, and then keepp trying to power on until it had eventually stopped. The pump operates even with the door open.
Problem is caused by a small float which senses the water level in the dishwasher, floating up and operating a microswitch, which turns on the pump to pump the water out. Obviously, if the dishwashe is filling up for some reason, you want the pump to operate even if the door is open. The float is in a small chamber - a very snug fit, with a hole in the bottom which is connected to the main pipework in the machine. There is another chamber next to the flot chamber which is also connected to the pipework. When the water level rises too high, water from this second chamber overflows into the flot chamber, raising the float and operating the pump. The water level then drops as the water is pumped out. The water level in the float chamber should also drop, but didn't on my dishwasher because the hole in the bottom was blocked (with old soap suds and grime I assume). Hence the pump just stays on. I assume in my case, the water flowed out very slowly, and eventually the pump stopped.
To fix it, removed the left hand side panel (2 screws on the front door lip. The back of the panel is just hooked on some raised bits of plastic). This exposes all the pipework, and the red float can be seen in it's chamber. I removed an extra couple of bits of plastic near the float chamber whilst I tried to work out what to do - but this may not be necessary. You will have to try for yourself. I couldn't get access to the hole to poke something in to unblock it, so I poured sink and drain cleaner into the flot chamber, topping up as it drained away, leaving it for approx. 15 mins. I think thick bleach would also work. Note: this cleaner won't be very good for any metal inside the dishwasher, so run 1 or 2 wash cycles to clean it out.
Maybe the dishwasher cleaner advertised on tv would have worked i.e. the stuff you put in the dishwasher on an emty cycle to clean out all the internals. I haven't used it, but it would be easier than taking the dishwasher to pieces.
Hope this helps
Mar 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Jan 03, 2008 | Dishwashers
Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
743 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
