Question about Nelson Sprinkler: Traveling Tractor
Spray arm missing - Nelson Sprinkler: Traveling Tractor
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
Ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Mar 01, 2010 | Frigidaire Dishwashers
The top spray arm of my Frigidare model FBD4315LFC0 Aqua Surge dishwasher fell off. Their appears to be a missing part. I've been searching online for a schematic and can't find one thorough enough to...
Hello there:
hey sorry i keep getting disconnected i will be back on really soon i need to find out what is going on i hope these things that i have discussed with you is helping you out the parts are not as hard as they look once you getthenew part it will have theinstallation instructions ok
Best regards michael
Dec 27, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Upper spray arm detached
The upper arm clips onto the upper drawer not onto the nozzles!
Jun 21, 2009 | Siemens SE24A230 ExtraKlasse Built-In...
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Apr 14, 2009 | Siemens Dishwashers
GE GLD5800L Middle Spray Arm is Not Spinning
The middle arm may be missing an O-ring at the back of the dishwasher.
Mar 23, 2009 | GE GLD5800L Dishwasher
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Spray arm not working
I have to remove my spray arm and put boiling water down the hole and tghen it works
Nov 14, 2006 | Danby 22 in. DDW396 Free-standing...
Nelson Sprinkler:  Traveling Tractor Logo
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
