Question about Homelite ZR10926 16" Chain Saw
My Homelite ZR10926 is difficult to start when cold. It starts great when warmed up. What can I look at? Also, what is the gap size for the mag?
  • johnr72hd Nov 12, 2010
    I have a new plug, good gas of the proper mix. It starts fine after warm up, just have trouble on cold start.
  • 7,733 Answers
Do a clean of all fuel components,change the spark plug (when you buy it go by the specifications on the store book the gap is set by factory) or the whole coil (aka spark plug cable and coil).Do a good gas / oil mix by 7.7 oz oil on 1 gallon gas (shake well).
Posted on Nov 11, 2010
  • Doctor PC
    Doctor PC Nov 13, 2010
    Small engines, including chainsaws, can be frustrating to start. This is especially true when starting a chainsaw just out of storage, when engine temperatures are extremely cold or when in need of a tune-up. Many times a new chainsaw will give you starting trouble right out of the box.
    Here is a step by step set of instructions that can make starting a chainsaw less of a chore. It has been developed from tips given by loggers who use the tool every day, year after year. The first big thing to remember is to keep the saw clean, make sure it is full of gas and oil and perform regular maintenance.
    If maintenance and tune-up isn't working. You just know the saw is a lemon. You've worked up a heart-pounding sweat and are sucking in air like a vacuum. Relax, all is not lost.
    turning everything off. Flip off the on/off switch. Turn the throttle off. Push or pull the choke to the off position and deal with anything else that might need to be switched off (off is the key word). Some even suggest removing the spark plug, pulling the cord a couple of times, then replacing the plug.
    Flooding usually prevents a saw from starting. Flooding is the major cause of a stalled chain saw engine. Flooding is caused by too much gas applied at the wrong time. You need to prevent or remedy the flooding effect.
    The rebooting step (step #2) will improve this condition. Another suggestion loggers make is pulling the engine's cord through 8 times with all systems off. I don't know if this actually drains the liquid gas or gives a bit more time to counteract the excess liquid gas but I am assured it works. Do it 8 times!
    Now. Set the on/off switch in the "on" position. The throttle "on" position should be turned on only as a last resort. Actually, I am told some late-model chainsaws specifically instruct you to tweak the throttle - so do it if instructed. Put the choke to the "on" position.
    The procedure in step #3 helps clear the engine of too much "liquid" gasoline. Again, putting down the saw down for a cup of coffee or soda will sometimes do the same thing.
    OK. Everything should be back on...
    By doing all this you will make the saw (and you) more comfortable and start the process of clearing a flooded engine. Just as important, you've given yourself a minute or two more to recoup.
    Make sure you have the choke in the "on" position. When you do, pull the engine cord several times through until the engine "pops" one time. A pop is a quick audible response and **** by the engine without cranking. Please, NO more than one pop with choke on or you risk another fatal flood.
    PLACE THE CHOKE IN THE OFF POSITION NOW!
    With the choke in the off position, pull the engine's crank cord through again. The engine should start in 1 to 3 pulls. Try it first without using the throttle control (unless recommended by the manufacturer).
    Colder weather or a saw just out of storage can complicate these instructions. Here is further advice. "If I haven't gotten a pop in four pulls I transition to the part throttle, no-choke position and if I haven't gotten a start in maybe 8 pulls I return to the choke position for one or two pulls. I am sure this varies with different chainsaws, but you shouldn't have to pull very many times in the choke position, even in cold weather."
    Maintenance:
    Here's How:
    1. Find your equipment/operators manual for parts description.
    2. Find the air filter. Refer to the operators manual.
    3. Detach the filter and clean with soap and water.
    4. Either substitute with a spare or let original dry and replace.
    5. Check all screws and bolts for tightness.
    6. Inspect the starter cord for free play in the spring when pulled out completely.
    7. Make sure the cord is not frayed and the handle is not broken.
    8. Find the flywheel and clean with toothbrush and a spray bathroom cleaner.
    9. Find the pawls and clean with toothbrush and a spray bathroom cleaner.
    10. Inspect chain for cracks and tooth wear. Replace when cracks appear or teeth are worn.
    11. Clean the bar groove and sprocket teeth at the end of the bar with the toothbrush.
    12. Make sure the chain catcher is secure and in place.
    13. Check the chain brake by running the saw at full speed and activate the break.
    14. The saw should stop immediately
    15. Service if anything is not working properly.
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
It's brand new, when I finally get it started it will run good for about 1 min. or less, and then it dies. I pull the choke out all the way, pull it a couple of times, push it half way in, it starts...
Hi paulbonser... Set your point gap to .20 using a feeler gauge... You can also use a paper matchbook cover, it ia approx. .20 to set the gap on the points. Please take time tor rate me
Sep 16, 2011 | Homelite ZR10926 16 Chain Saw
I have homelite UT10560 chain saw. The problem I have is it will start and run when cold. But if the saw shuts off it is very hard to start again. What is the trick to start when saw has been runing...
Make sure you have control set on run,not choke or start. Check spark aresstor by removing exhaust cover and cleaning screen of carbon and oil build up with spray carburater cleaner and fine wire brush.Also remove gas cap and make sure that vent hole in cap is open.Otherwise it can draw a vacumn after being ran for awile and be very hard to start.One last thing is make sure that spark plug gap is correct and that there are no hairline cracks in porcelin insulation. Best of luck. Thank you.
Apr 20, 2011 | Homelite ZR10926 16" Chain Saw
My dad owns a 3 yr old Homelite chainsaw. he is bringing it to me to repair. The chainsaw runs great and as it warm up the idle will rise to the point were it is full throttle and you can't get it to idle...
Check the throttle trigger assembly for free play. You may have to remove the handle section over the trigger to remove sawdust/dirt. Idle changes are usually due to air leakage behind the carburetor--check all fasteners on the carburetor including the ones holding the carburetor to the cylinder. Check the muffler and air cleaner for plugging. Check the cylinder for looseness to the crankcase. Check the throttle return spring on the carburetor to make sure that it is working correctly. Hope some of this helps!
Jun 13, 2010 | Homelite ZR10926 16" Chain Saw
Flywheel to mag. clearance
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Homelite ZR10926 16" Chain Saw
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
Chainsaw won't start when warmed up
Coil is possible, change the plug (cheap insurance) and try it. If problem persists try this shortly after it quits.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
An index or business card is good for gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, then tighten coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel.
Homies are bad for clogged fuel vents too. When it begins to sputter roll it onto side and loosen fuel cap. If ti smooths out and runs properly it has a clogged vent. HTH
Lou
Dec 22, 2009 | Homelite Garden
Forgot how to start it
Put the choke on, and if it has a primer bulb, push 3 times, then crank it.
Jim
May 31, 2009 | Homelite ZR10926 16 Chain Saw
Difficult to pull the start chord.
Posted by m_mcneley on May 14, 2009
Difficult as it takes two guys to pull it out? Have you tried taking the recoil off of the machine and pulling it? If recoil pulls easy off of machine then try rolling the saw over by hand. If the saw resists rolling over manually then you could possibly have a burnt up engine. Do you have to mix gas for operation
You must help us if we are to help you.
May 14, 2009 | Homelite ZR10926 16" Chain Saw
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Homelite ZR10926 16" Chain Saw Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
