Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
Hard Drive Plugs and Wires
For a friend that has come across the E-Machine needs assistance in where the 3 unattached plug wires belong. He need's to know the exact location where they should be placed. Can you help with a diagram of the inside board, (blueprint if you would) this would probably be the best bet. He is very smart when it comes to refurbishing such equiptment, only thing missing is the simple whereabouts as to their placement. Any info. I can pass along would be greatful. Thank-You for your time.....
  • alfieri Jun 19, 2008
    Still waiting for one of you "experts" to assisit poor little me with my problem. Any suggestions out there? Perhaps a name or address you could link me to that would assist in "Where Does This Plug In" would be a great start. Have a Great Day. Again, this is regaurding a e-machine ATX300-12e/rev-D. 3 unplugged wires, where do they belong?
  • grenville2 Jul 11, 2008
    tried to replace bestec 250 12e for my emachine not completely sure all of the wire connecttions i plugged in green light is on but comp still isnt working any ideas out there
  • 144 Answers
Can you post a photograph to assist you better???
Posted on Jun 22, 2008
Y? it is heatsink near a processor!
and what are the function of north bridge chipsit?
Posted on Nov 06, 2009
Listen, you can only plug the power supply into the devices you have. ( one HD equals one hookup, one floppy, etc.) Unless you have a device to hookup to EACH plug, don't worry about the extra plugs. I suggest if you don't know this to stay out ouf the inside of your PC...
Posted on Aug 27, 2008
I'm no expert but power supplies have connectors for a typical number of peripherals, some of which you may not need. Extra four wire connectors are normal. As long as all of your drives and devices are connected to the power supply, don't worry about extra unneeded connectors. They all get the same voltages (it goes by wire color).
Posted on Aug 21, 2008
The solution to the wires is
you need to buy a new hdd to plug them into.
your emachine is same as mine i think and i just
put a hdd in
and a extra video card
still working on pc
your emachine can be upgreaded as the motherboard is exstremly powerfull i was going to get new desktop but no point
Posted on Aug 18, 2008
How do i reconnect the wires on the high/low and forward/reverse on a 12 volt quadbike
I don't have the diagram. But green wires are always ground. The two yellow wires, if it goes into a plug, plug it in. Most plugs are what I call, iddiot proof. Not meaning you are one. But the plugs will not go to another plug. If you have to put a lot of force to get them to go together. They don't belong together. Just remember that some plugs don't go to anything. They make these harnesses to fit multiple vehicles..
Dec 28, 2014 | Cars & Trucks
Steps to change a spark plug
easy job replace one spark plug at a time.you need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug wires.you need basic 3/8 ratchet wrench.you need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
I have a friend who owns a bmw 323i that is a 2000 and it is skipping and he like to know what could cause this problem to make his car act like this..
I would start by giving the car a tune up. New spark plugs, spark plug wires, fuel filter, and air filter. Usually a car skipping is caused by needing new spark plug wires and spark plugs.
Nov 02, 2010 | 2000 BMW 3 Series
How do you replace glow plugs on 1999 peugeot expert please
You will need a decent 13mm spanner and 3/8 drive socket for the plugs and a 8mm spanner for the wires, remove the airfilter and pipes to get clearance, you can leave the battery in but ingition off. Unbolt the wire across the 4 plugs, note where the power in cable doubles up on one plug. Using a combination of spanner and socket change the plugs one at a time, they can be tight (normal thread, undo anti-clockwise) I reccomend genuine peugeot plugs or at worst Bosch fast start ones.
Mar 08, 2010 | Vans Cirro Snowboard Boots
I have a 2003 Ford Ranger 3 liter. I just changed
Did you replace the wires? if not you may have broken a couple of wires. Not sure what fire wire is unless you mean the spark plug wires. Also did it do this before you replaced the plugs? need to know.
Feb 24, 2010 | 2003 Ford Ranger Regular Cab
I DONT KNOW WHERE Tto pug in the power
Power Led?
hard drive Led wires?
If you are building a machine these areusually pluged directly into the motherboard.
the plugs are usually only compatible to their special sockets on the board. all you need to do is to examine the plug ends and look for sockets withsimilar shape and size as the plug.
Jan 05, 2010 | E-Machines eMachines Desktop PC
Need to know how to change plugs and wires on a 98 pontiac firebird (am a female gentleman be easy lol)
You will need a 5/8 sparkplug socket for a 3/8 drive ratchet
A 3/8 drive extension bar
A 3/8 drive ratchet
Pull wire off of spark plug, slide socket over plug, turn counter clockwise until plug comes out. Some might come out hard, and some are a son of gun to get at. To install, it's just reverse, but don't really crank down on them when you tighten them. At the same time, you can replace the wire on each plug you take out. Do one at a time, that way you won't screw up the firing order. Good luck.
Oct 20, 2009 | 1998 Pontiac Firebird
There is an extra plug of wires dangling in the pc when I take off the metal side panel and look inside. Is this normal?
Yes... usually u have lots of spare wires and plugs from your PSU or some unattached case connectors.
Mar 26, 2009 | HP Pavilion Media Center TV m7360n...
Cam shaft senor
It is part of the distributor according to a chevy forum I belong to
Oct 29, 2008 | 1996 Chevrolet Blazer
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
995 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
