Question about Kitchen Ranges
I have frost building in front of the face plate covering the interior light and at the door were it meets when it is closed, also it is building slightly to the left where the sticker is placed by the manufacture on the interior left hand side were plastic meets metal and on the door it self when closed every three days or so I have to use a wet cloth to remove it there is nothing blocking the door when closed and this has been going on for the last year or so, my alarm has not sounded and everything is froze solid
  • Kitchen Ranges Master
  • 3,051 Answers
Hello there
Here is a couple of things that need to be checked fully ok
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Posted on Nov 12, 2010
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
90 toyota camry keeps beeping when door is closed and car is shut off.
There should be a switch in the door opening usually on the front pillar between the hinges or at the bottom where the door meets the body at the back,that controls the interior light and possibly the beeper, If it has gotten out of adjustment, or is broken for some reason could cause your beeper to keep going. Check to see if your interior light is staying on as well.
Sep 10, 2011 | Toyota Camry Cars & Trucks
Bottom freezer/compressor works, top refer area not cold! I do not think the blower that transfers cold freezer air to the top is operational. I would like to know how to get at the fan motor, etc. to...
The fan that moves air into the fresh food compartment is in the freezer. If you open the freezer door and hear the fan, then you know it's ok. Gaining access to the fan motor requires removal of the freezer door, glides, and interior back cover. The door track system utilizes a rack and pinion type design, and if it's not put back together properly, the door will not close and seal.
If the fan is running, there is a motorized damper (flap) in the top rear of the fresh food compartment. If this damper is not opening as it should, the compartment will be warm.
The most common issue for you symptom is a defrost system component failure. Look on th interior back wall of your freezer for a build up of frost or ice. If this is the case, air flow is restricted because the evaporator col ice blocked with frost and ice. This repair also requires the removal of the door, glides, and evaporator cover. If you have any doubts of your ability to get the parts put back correctly, you should defer repairs to a qualified appliance service technician.
Nov 18, 2010 | Maytag MFF2557HES Stainless Steel French...
The interior light does not go off when the door is closed apparently because the door is not closing properly. Problem with the seal round the door? The light knob does go off when pressed manually. The...
ck the light sw . as if the door was the light problem then you would be loosing so much cold that the food would go bad and frost would build up ..
Aug 11, 2010 | Neff Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water leaking in the regrigerator and falling /frost build up
the door may be sagging or the door gasket could be torn or loose from the door. whats happening is the moisturew in the air is forming ice build up. check and make sure the door and gasket are completely closed.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
When printer turned on error Dueplex cover
The duplex unit is located on the right side of the copier (facing the copier) The first cover you open (the side door that hinges down) is the duplex unit.
Make sure it is closing properly and fitting tight against the main body.
The open close sensor for the ADU is located at the rear top side of the door. Their is a round hole with a metal plate behind it - this is the actuator for the sensor behind the plate.
To test it, open the door (leave copier on) and press the metal actuator in with your finger - the copier should come to the ready.
When you close the ADU look to see where the actuator/hole meets up with the main body of the copier - there should be a "boss" sticking out from the cover - this is what pushes the actuator to say the door is closed (is it there?)
You could also remove the small plastic cover on the ADU that is cover the side where the sensor/actuator is located. Make sure the sensor is still in place and connected.
You could also try unpluging and repluging the main connector that conects the ADU to the copier (make sure copier is off)
Mar 27, 2009 | Toshiba Office Equipment & Supplies
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
