Question about Panasonic CQ-C8303U CD Player
I took my panasonic cq-c8303u out of my jeep and put it in my civic hooked all the wires up right but no power to my deck whats could the problem be?
  • 863 Answers
Check the in line cylinder fuse for the radio, cause they blow easy. Also, check the radio fuse under the dash or wherever your fuse box is located. Make sure you solder the connections for a good contact, cause just wrapping electrical tape around the wires will cause you problems down the road when you go over bumps.
Posted on Nov 11, 2010
Can this be hooked up to cell phone???????
Yes it does as long as your phone supports bluetooth. Here's a link to the manual. You can download it for free. http://service.us.panasonic.com/OPERMANPDF/CQC8403U.PDF
Jan 12, 2011 | Panasonic CQ-C8303U CD Player
Panasonic cq-c8303u wiring diagram
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Panasonic cq-c3100u
scottmar7- You need the wiring diagram for your panasonic deck,the diagram is as follows.
red- 12volt key switched
yellow-12volt constant-memory
black-ground
white-left front positive
white with black stripe-left front negative
grey- right front positive
grey w/black stripe-right front negative
green-rear left positive
green w/black stripe-rear left negative
purple-right rear positive
purple w/black stripe-right rear negative
blue- remote turn on- for amplifier
These are all the wires you should need,to hook up you deck.
If you need anything else let me know,I can help you,happy listening. cooltek mar,14/08
Mar 14, 2008 | Audio Players & Recorders
Panasonic CQ-DF903U CD Player
When you unhooked your deck it still had power going to it, you need to unplug your car battery and plug it back in that should reset the deck and get the error message to go away.
Good luck,
Chris
Feb 27, 2008 | Panasonic CQ-DF903U CD Player
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U CD Player Logo
87 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
