Question about LG WM2688HWM TROMM SteamWasher
Not Draining, check drain hose and filter - LG WM2688HWM TROMM SteamWasher
Macmarkus
  • 2605 Answers
SOURCE: wahser not draining. i have checked the drain hose
Welcome to FixYa.
Since you've stated already checked the drain hose and it is not clogged, I'd suggest the following procedure.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
As someone who has plenty of experience servicing Bosch I can tell you this is the most common reason for these machines not draining.
NOTE; Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Nov 14, 2010
  • 291 Answers
SOURCE: how to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Posted on Dec 20, 2009
  • 161 Answers
SOURCE: My LG Tromm WM1814CW is not draining. I cleaned
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Posted on Jan 27, 2010
j_alcaidinho
  • 107 Answers
SOURCE: not draining. cleaned hoses. where is this filter
You need to get into the where the pump assembly is, if there is a kick plate you need to take off, if not you need to get in through the back of the unit
Posted on Feb 26, 2010
marka19
  • 1430 Answers
SOURCE: Our washer is not draining all of the time. The
Try this link for the filter http://mediasuite.multicastmedia.com/player.php?v=p83k1mb1
and this one for the pump repair
http://appliancehelponline.com/frontloadpumpvideo.html
or this one
http://appliancehelponline.com/washerdrainpump.html
Posted on Jun 11, 2010
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Washing machine is not draining water from drum on completion of cycle
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Mar 20, 2011 | Bosch Washing Machines
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
I ahve a DC900PC dishwasher that is not draining , I cant get to the drain hose, need help, thanlks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 01, 2011 | Whirlpool 24 in. DU900PCD Built-in...
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Daniel
Dec 13, 2010 | Dishwashers
Dishwasher isn't draining
Hi
Daniel
Oct 25, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher is not draining
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Jul 22, 2010 | Bosch Dishwashers
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Jan 26, 2010 | LG WM1814CW Front Load Washer
Draining problem
u take your front panel off at the bottom then u should see the drain pump and drain filter remove the filter check for blockage if none pump will need replaced odds are u have your filter clogged with some change or sock
May 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
383 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
