Question about Fisher and Paykel GWL11 Top Load Washer
F & P 603 Top Loader
Power on at machine. Lights on in normal sequence. Push start button & nothing happens. What gives? Do I need a new control board? Or is this a simple problem?
  • 28 Answers
Lid switch possibly open circuit
Posted on Jun 21, 2008
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 703 top loader, lights go on but pressing them even to start does nothing not start or let me change the size of the load ;(
Hi, just read your posting.Now the possible fault could be your display board.When you turn the power on to the machine from the power point do all the lights come on and you hear an audio beep beep , then the lights go out ?If that happens, then do you push start and can not select anything else like water temp or load size?Or do a series of lights light up and it beeps indicating a fault code after you have pushed the power button? Please reply and I can guide you throe step by step the process needed to fix this problem.
Jun 05, 2010 | Washing Machines
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Dead lg WM2432HW front loader
check the power filter board. it's the first component that the power cord encounters in the machine; before the main board.. should have 120volts in and 120volts out. there have been problems with the wiring harness between the main board and display board. these are both rare though. it's almost always a main circuit board failure. i don't think a new door switch will solve your problem.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Whirlpool WTW6600SB
its under warrenty call for service if you attempt to fix it it will void the warrenty
Dec 05, 2007 | Whirlpool WTW6600SW Top Load
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Fisher and Paykel GWL11 Top Load Washer Logo
81 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
