Question about Electrolux Vacuums
What exactly is the name of the tool to remove the one screw on the handle of the Electrolux Renaissance C134A vacuum?
  • D Moss Nov 11, 2010
    The recess in the head appears six-sided like your pic with a bump in the center.
  • D Moss Nov 12, 2010
    Thank you, thank you, thank you. On the way to Lowes as we speak.
    President:
  • 1,140 Answers
It's not a particular tool, it's simply a type of screwdriver bit. They are called either "Torx" or T-Star and come in a range of sizes, e.g. T15, T20, T25, T30, etc.
I think the one on your vacuum is a T20, but it's hard to remember the size of every screw on every appliance. I've attached a picture below to assist you. If this isn't the right tool, please describe the shape of the recess in the head of the screw and I will post back with the correct answer.
Regards,
BElectric
Posted on Nov 11, 2010
Testimonial: "Was very helpful, pointed me in the right direction & it worked. Thanks."
  • 3 more comments
    The recess appears to be a six-sided star, but with a bump in the center.
  • DILLIGAF
    DILLIGAF Nov 12, 2010
    Ah yes, it's a Security Torx Head screw. You need a Security Torx screwdriver / bit. Ask your local hardware store or search online for a supplier. They are fairly easy to get hold of - I'm pretty sure the size you need is T20 but it's best to buy a set of various size bits and a bit holder. Shouldn't cost you more than $10 delivered. http://cgi.ebay.com/380285664346
  • DILLIGAF
    p.s The eBay link was only intended as an example. It wasn't necessarily the best or cheapest set available.
    Went to Lowes
  • DILLIGAF
    Glad I could help and you got it fixed - that's what we're here for. Your acknowledgement is appreciated!
How do I change the air filter
the top of the vacuum where the tools go comes off,the filter goes underneath..Chris
Jun 25, 2014 | Electrolux Guardian Bagged Canister Vacuum
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Renaissance manual
disconnect the power from the unit, then remove two screw in the handle and pull the handle apart and this will expose the wires.
Jul 19, 2013 | Electrolux Vacuums
I just need the part number for my Guardian Electrolux model C134A i ran over the Hose and that was the part that broke. i need to compare prices so i can determine if it is cost effictive to change the...
The part number for the hose is 47086.
The best thing to do is contact the nearest Aerus Electrolux dealer.
If it's just the switch or handle that broke, it will be more cost effective to have that replaced. If I remember right, the hose costs close to $200 new. A new switch may cost up to $20, but probably quite a bit less.
The nearest Aerus store can be located using the below link.
http://www.aerushome.com/storelocator/
Mar 29, 2011 | Electrolux Guardian Bagged Canister Vacuum
Whwre do u put the pre-motor filter on electronic renaissance vacuum
The filter goes under the tool caddy. Press the latch just behid the bag door. Prees the two tabs toward each other to release the catch of the tool holder and lift out. Remove filter and replace.
Slip back of tool caddy in first, then press front down to latch it. Close the top and you're done.
You cann find a manual using the following link. It's the next to last one under Older Models.
http://www.aerusvacuums.com/support/manuals/index.cfm
Mar 02, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Dec 04, 2009 | Electrolux Vacuums
Electrolux renaissance how to change power headlight
You will need to remove 5 recessed screws from the underside of the head, Then remove the cover and examine the bulb.
You may need to find an AERUS Electrolux service center for parts. Might as well clean out all the dust around the motor and remove and inspect the belt while you are in there.. Check the belt tension before loosening
Nov 08, 2009 | Vacuums
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Mar 28, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Vacuums Logo
202 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
