Question about Refrigerators
GE Side By Side Profile TFH24PR
Had turned the refrigerator off while home was not occupied and when we went to turn it back on, the lights come on but I don't hear the compressor coming on and it is not getting cold. We tried tripping the circuit to see if it would come on but nothing.
  • 237 Answers
SOURCE: refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Posted on Nov 24, 2006
  • 237 Answers
SOURCE: side by side not cooling
Couple of things... first need to see if the compressor is really hot to the touch and "clicking" on and off every 3-5 minutes due to high heat (trying to start). If that's what is happening you likely have a "start device" failure (little box on the side of the compressor). If the box is white in color and you pull it off and it makes noise when you shake it (along with little bits of debris falling out) you know it's bad. They make a kit to fix that known problem. If the compressor isn't trying to start but actually runs quietly... check that the cooling coil isn't all iced up preventing proper air flow inside the cabinet (take the panel of the rear inside of the freezer section to check it). If that is all a block of ice basically you likely have a defrost cycle problem (defrost t-stat bad, defrost timer bad, etc.). Other than that you should have a little fan right above the coils to move air around, if the compressor is running and the compressor fan (called condensor fan) is running then this fan (called evaporator fan) should also be running to move the cold air around. If that fan is dead then you will have a nice cold coil but no air flow over it to cool the rest of the refer/freezer properly. Let us know what ya find out.
Posted on Dec 29, 2006
SOURCE: GE Profile does not run.
Yes, I have the same problem with GE profiler model PSC23SHRSS. " The compressors and fans are not working, but the interior lights do. All exterior indicator lights are flickering on and off, and temperature control display and buttons not working. "
Posted on May 30, 2007
  • 105 Answers
SOURCE: Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Posted on Jan 25, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Need doors for GE profile TFH24PR refrigerator
Complete doors can usually be purchased from GE themselves for models which had problems with sweating on the exterior. Other models I'm not sure it's possible to get.
Ge can be reached at 800-626-2000
Aug 23, 2009 | Refrigerators
The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Jul 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice maker will not work
check icemaker lever you did not turn the ice maker off
Mar 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Refrigerator
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE profile side by side-
the defrost timer is factory set on defrost. turn the time a notch or 2 and it should com on
Nov 22, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile Artica
The main PCB at the back of the appliance has failed
Nov 12, 2007 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
789 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
