Question about Fisher and Paykel Ovens
Pepper Oven overheats
Hi,    My issue is with my Fisher&Paykel Pepper Radiant oven and the fact that it doesn't seem to turn off the elements when the required temperature is reached.     This morning while baking I could smell my goodies burning and was dumbfounded as to why this could be happening as none of the ovens settings were different from all my other successful baking endeavors.    When I opened the oven all my buns were burnt and the temperature from the oven seemed to get hotter.    Any help with my over heating problem is greatly appreciated.
Kind regards, Geoffrey Tama.
    Champion:
  • 254 Answers
This problem is caused by a faulty thermostat controller. This is the dial that you use to set the temperature for heating.
Posted on Jun 22, 2008
Hi, the two cooktop elements on the left of my Fisher and Paykel in-cabinet oven with ceramic cooktop do not turn on. The switch light doesn't turn on, but the right side elements work.
normally there is a live wire for right and one for the left this maybe off,turn off at wall and remove the back to see any wires that maybe off
Nov 05, 2016 | Fisher and Paykel Ovens
F & P Pepper stand alone oven. How do you get the top element plates out to clean them properly?
You can't they are permanently wired in. They swing up so you can wipe out the drip bowl.
Aug 25, 2016 | Fisher and Paykel Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
Fisher paykel problem
sounds like you have a problem with the thermostat it may need to be replaced. \you can goole appliance parts and you will see a number of dealers you can get parts from
May 04, 2014 | Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a fisher & paykel Astro built in wall oven which has a problem, after using the oven and then turning both switches off for some reason the rear element continues to stay on and will not switch...
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
Aug 07, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I have the fisher paykel pepper electric stove top and oven at home. the stove is working just fine, but below it the oven turns on but it doesnt heat up. what should i do?
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working.
Oven element is faulty - check by performing continuity test;
Wiring at oven element terminals burnt off - check visually.
If you are handy carry out the above. If not, call a repairman.
Feb 15, 2011 | Ovens
Fisher & Pak\ykel element connection
white or red are phase, black or blue neutral
Mar 25, 2017 | Fisher and Paykel AeroTech Double OD302...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Ovens Logo
467 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
