Question about PfaFF Sewing Machines
My Pfaff 1475 CD sewing machine lifting lever for the pressure foot will not move up or down
SOURCE: Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
Posted on Dec 28, 2008
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: How do I remove the face plates on a Pfaff
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
Posted on Nov 10, 2009
  • 148 Answers
SOURCE: I have Singer sewing machine Model #9117. The
PUT OIL AND SOAK IT FEW HOURS
Posted on Apr 05, 2010
SOURCE: My Pfaff 1475 CD stated batterie pile battery when
turn the machine to "on". Tip the machine on its back and you will see a little door on the left-hand side. Open the door from left to right and inside are two AA batteries. Change the batteries (both batteries go in with the at the top). Close the door, upright the machine, turn it off and turn it on again. The display will be 0 0 2.5. It's now ready to go.
Posted on Oct 25, 2010
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
I couldn't lift the lever of the pressure foot in novamatic. 2000 sewing machines
Try to remove the latch on the foot. It sounds like the foot is nailed down with thread. You should be able to move the foot control up and down. You can remove the front of the machine and peak in at the foot lever to see if you see if there are any globs of thread.
Dec 08, 2016 | Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
I need to reattach the spring to my walking foot on my 1475 cd pfaff sewing machine if you have pics that would be very helpful, thanks
I don't have that mwchine any longer but I think you might get an answer on Pfafftalk.com for this question
Jul 27, 2014 | PfaFF Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
I have a pfaff hobbylock 796.
Has any little kids been around lately? Have they had access to your sewing area and machine? (thinking perhaps the pressure foot tension has been tightened down) If it has been tightened, losen it a couple turns, see if that helps (remember, left to loosen, right to tighten)
When is the last time you oiled this machine? Typically sergers require a clean and oil each time you go to use them. Locate the bar that correlates to the presser foot add a drop of oil to the bar and let it seep in. After a few minutes try lifting the presser foot.
Also does the presser foot lever move at all?
Aug 20, 2012 | PfaFF Sewing Machines
Dec 31, 2008 | PfaFF Tiptronic 2030
Pfaff 6122 Problem
Sep 24, 2008 | PfaFF Creative 7570
Sewing Machines Logo
115 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
