Question about Frigidaire FTF530FS Front Load Washer
Washer is a 6 cycle heavy duty front load that is 5 years old it smells bad water odour
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Posted on Dec 27, 2010
5 month old Whirlpool Cabrio washer has moldy smell. Tub seems to empty well. Any ideas?
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
May 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
I have a front loading washing machine that smells inside. Any suggestions ???
Jun 22, 2009 | Daewoo DW500M Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
A mold smell from my washing machine
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Smell coming from washing machine
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
