Question about Husqvarna Chain Saw with 18" Bar
I took my new 445 out of the box, filled the oil tank with Husqvarna chain and bar oil. Mixed the Husqvarna oil for the gas in a one gallon gas container, mixed well and filled the gas tank. The engine cranked eaisly and I let it idle for a few minutes to warm up. I goosed the throttle with the saw near a piece of cardboard and saw a very fine light oil line. It wasn't throwing oil all ove rthe place like my other two saws, but I thought maybe it was just frugal with oil. After about fifteen minutes of use I pulled the trigger and it bogged down. I checked and the chain, sproket, bar were all dry as a bone and froze up tight. I took it back to Lowe's and exchanged it for a new one. I came home, filled it with gas and oil and made two cuts, stopped the saw and checked the chain. DRY as DUST! I read the manual and found that this model does not have an adjustable oil pump, so . . . . what gives? I have a tree in my yard I need to cut up.
    Brigadier General:
  • 4,088 Answers
According to my Husky selection catalog for 2009, the 445 saw does have an adjustable oil pump--it should be located on the under side near the chain return area. They are usually just a screw head that is level with case surface--turn it CCW to increase flow. I'm surprised that the flow rate could change that fast--perhaps the oil pumps are failing due to some manufacturing defect. If turning the adjustment doesn't improve things, take it back and select a different model. I'm surprised that Husky would allow such things to occur. Hope this helps!
Posted on Nov 11, 2010
  • Doctor PC
    Doctor PC Nov 13, 2010
    Husky or Husqvarna?
  • 7,733 Answers
Did you use "chain oil" or regular or mixing oil?
Chain saw motor is smoking
Hi Mark:
I'll go over the basics so please ignore what you already know.
Chain saws are 2 cycle which means the gas must have oil added. The ratio is 50:1 typically.
Chain saws are air cooled so they get HOT. They like to be kept clean, and a build up of oily sawdust is an invitation to an unwanted fire.
The chain is lubricated by a thick oil that gets put in a different tank. If you run out of chain oil, the chain will get really hot and you can actually ruin the bar by overheating it. A good rule is to always fill the chain oil tank (with chain oil) at the same time that you fill the fuel tank (with gas/oil mix)
Make sure the chain is kept SHARP. A blunt chain makes the saw work harder and causes friction which generates heat.
On a regular basis, take the bar off and clean the brake assembly and all the bits and crannies. Compressed air and solvent will make the job easy.
Chain tension should be kept snug but not too tight. I like to be able to lift the chain at the centre of the bar and have the underside just barely clear the groove in the bar.
Lots of bars have a roller at the tip and there is a fitting to inject grease. It's a good idea to use it regularly.
I think that about covers it. If you have any specific questions, send 'em on.
Apr 30, 2015 | Garden
I filled the gas tank in my chain saw with bar oil. Is there an easy way to remove the oil from the carburetor and get it started?
Dump out the bar oil and put in some pure gas and shake the saw to thin the bar oil. If it has a primer bulb push it a few time to flush the oil through. Dump this out and put in the proper mixed fuel and try starting.
Nov 03, 2013 | Husqvarna Garden
Which oil do i use in a ryobi C4620 chainsaw?
Do NOT use lightweight motor oil for that bar! Use only bar/chain oil for it - nearly any brand will do just fine, but it needs to be bar/chain oil. Bar/chain oil is specially formulated to stay on the bar & chain in use - motor oil will fling away & your bar won't get the lubrication it needs.
For fuel mixing, use nearly any brand of 2-cycle oil, which is specially formulated to provide lubrication even when it's mixed into your fuel. Use about 3.2 ounces of 2-cycle oil per every gallon of gasoline - a little more won't hurt (it'll make the saw smoke a little), but never use less. Always shake the gas can just before you refill your saw's tank - shaking helps make sure the oil & gas are well-mixed.
Mar 13, 2013 | Garden
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Hi i have a Husqvarna 445 18" 45.7cc the automatic
Verify you have oil in the oil fill tank. Try cleaning inside the drive sprocket cover. Release the chain tension and carefully dislodge the bar and chain assembly. Clean sawdust and debris from behind and inside the housing and behind the bar. Use a wisker wire to clean the through ports and channels on bar( these ports are the path that the oil travels to the drag groove that the drive links on the chain uses to pull the oil to the tip of the bar).
Please refer to this link below for your saw maintenance-
http://www.chainsawsdirect.com/manuals/HUSQ_445_MAN2.pdf
If this does not correct the problem contact Husqvarna customer service or a local service repair.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Haven't used my Huskqvarana Chain Saw, Model 61, 1983 in awhile. Am cleaning it up and can't find instructions for gas:oil ration if oil is necessary. Can you help me?
50:1 using fresh fuel and a modern synthetic saw oil mixed in it's own can. Be sure to shake the can thoroughly just before filling the tank each time to avoid oil starvation. Don't mix more than one gallon at a time unless your business is sawing. Be sure to replace the fuel filter and probably the fuel lines. Replace the air filter and clean the muffler. You may need to clean and rekit the carburetor if it has been in storage for some time. If the spark plug has worn electrodes, replace with new and gap at 0.020". Spark should be blue and 'snappy'. Make sure the chain oiling is correct by running the bar tip near some cardboard for a moment or so--it should leave a thin line of oil. Hope some of this helps!
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
MY 445 BOGS DOWN AFTER 10 MIN OF RUNNING
Make sure the bar/chain is not being run dry of oil. Make sure that you are using 50:1 fuel/oil with fresh fuel and modern synthetic saw oil, not boat motor oil. Shake the fuel can vigorously just before filling the tank each time. If loosening the fuel cap for a moment when the saw bogs down restores power, look for a plugged fuel vent. Check the air cleaner and muffler for plugging. Hope this helps!
Oct 17, 2010 | Husqvarna Chain Saw with 18" Bar
OIl gas mixture ratio?
one small bottle of oil from the auto parts store ( i don't know the oz. size)to one gallon to one gallon of gasoline; mixed well
Jul 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw with 18" Bar Logo
594 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
