Question about Samsung WEP460 Bluetooth Headset
My samsung WEP 460 bluetooth won't pair with my ps3
SOURCE: samsung bluetooth device pass key ?
key 0000
Posted on Oct 08, 2008
CRTN
  • 716 Answers
SOURCE: Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Posted on Mar 04, 2009
dvs9mm1971
  • 114 Answers
SOURCE: how do I pair my WEP 200 samsung bluetooth to my
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
Posted on Oct 15, 2009
  • 64 Answers
SOURCE: My samsung wep 301 will not pair with blackberry
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Posted on Jan 15, 2010
  • 406 Answers
SOURCE: how to play music of
The samsung Wep-460 is designed for data communication, or in other words making phone calls without the hassle of a wire. However music streaming via phone or computer is not supported. It doesn't have that capability. IF you want to listens to music wirelessly using bluetooth, you should get headsets or earphones that has, Advanced Audio Distribution Profile aka A2DP. It is a Bluetooth profile that allows wireless transmission of stereo audio from an A2DP source (typically a phone or computer) to an A2DP receiver (a set of Bluetooth headphones or stereo system). In short you need to have a bluetooth headset that has A2DP
Hope this clears the confusion
Posted on Apr 07, 2011
I have a samsung galaxy s3 and i can not pair up my samsung wep-460 how do i reset it
ok you need to hold the power button the light will flash, but still keep hold the button and the light will chance a soild mode. then start scan the bluetooth on your phone, and it will find it. the pass code is 0000
Jun 28, 2012 | Samsung WEP460 Bluetooth Headset
I cannot find my passcode for my Samsung Bluetooth WEP 460...can you help?
It is hardcoded to '0000' (four zeros). Anyway, put your headset in pairing mode, prior to trying to pair it with your phone. If it has never been paired with another device before, just by turning it on, it should enter that mode, denoted by its indicator light being steadily lit in blue. Otherwise, turn your headset off. Then, press and hold the Muiti-Function Button for far more seconds than the time required to turn it on, until its indicator light is steadily lit in blue. Then, within the next couple of minutes, bring your phone and headset close to each other, and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make your phone connect to it. If a pairing code (or PIN, or passcode) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There should be an indication on your phone too, that the pairing process has been successful. Otherwise, turn you headset off and repeat the pairing process all over again.
Hope you are able to sort your problems out soon. Anyway, please, let me know if I can help you any further.
By the way, if your headset's quick start guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Jun 11, 2011 | Samsung WEP460 Bluetooth Headset
How to play music of windows to samsung wep 460?
Apr 07, 2011 | Samsung WEP-150 Wireless Headset
Wont play sound anymore worked fine the other day but now i cant hear anything when i use it, its paired with my phone and is fully charged
Were you able to find a solution to this problem? My samsung wep 460 started doing the same thing today. I can hear tones but no sound from calls. Thanks! bobbybrooner@gmail.com
Dec 29, 2010 | Samsung WEP460 Bluetooth Headset
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
Forgot code
Try dropping the wep460 from the connection list and
re-installing. That may work
Oct 20, 2009 | Samsung WEP460 Bluetooth Headset
I got a new phone and need passcode to pair my bluetooth.
In the user guide, it says the default passkey is 0000
Sep 27, 2009 | Samsung WEP460 Bluetooth Headset
I need pairing info for my wep185 headset
1. activate bluetooth on handset (phone) then immediately.
2. Press and hold mute switch on wep180 for 8 secs until led flashes blue. Release button only after you see the flashing blue led which indicates the WEP180 is active.
3.Enter the pin 0000 which is the default pin code on the WEP 180 and the handset should connect to your WEP 180 - I dont know how to get it to pair with the PS3.
Jul 11, 2009 | Samsung WEP180 Wireless Headset
How to pair the bluetooth headset to the ps3
This is the info i got when i was looking to pair my headset with my PS3.
1. Turn your bluetooth headset on. It should flash on/off every few seconds.
2. Go to Settings > Accessory settings > Manage bluetooth devices.
3. Put the headset in "pairing mode".
4. Start to scan for the device. PS3 should pick it up. It will display the model if successful.
5. Once it's found it hit the options button. Connect the device (pairing mode) A blue icon will pop up.
6. Your headset will stop flashing meaning it has connected successfully.
7. Go back out and click on the audio device settings.
8. Input device > select "your headset". > output device > "your headset".
9. Hit the "connect bluetooth" icon. Then OK.
10. Your headset should now be successfully connected.. start talking into it to see the bar level move up and down to confirm its working.
Hope it helps.
Best Wishes,
Karlos
Jun 28, 2009 | Radio Communications
Samsung WEP460 Bluetooth Headset Logo
304 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
