Question about HP DeskJet 3940 InkJet Photo Printer
HP 3940 Not Printing
When I send a print job to the 3940 it appears in the print job window very briefly saying that it is spooling and then it disappears never to be seen again. Can't get it to print anything. Not sure what to do.
I not have the CD driver.
Posted on Jul 09, 2008
How to solve hp laserjet p2015 printer problem show excamation
If you are recieving memory errors, it is because the information you are sending to the printer is too large for it's internal memory to process. There are a number of things you can do.
- install more memory into the printer if your printer allows that (check your user guide)
- send smaller jobs (if sending multiple page jobs - break them into smaller counts)
- Make sure to use the PS driver for pdf and photo printing, and the PCL driver for plain text.
Also, in the Printers and Faxes window (can be found in the control panel if it isn't on your menu) right click on the icon for your printer and select properties. Select the Advanced tab and make sure these two settings are marked
- Spool print documents do document finishes printing faster
- Start printing immediately
May 17, 2012 | HP Office Equipment & Supplies
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
The print job in the print queue is preventing other print jobs from printing im receiving this error message i have a hp c 4580 printer
If one job isn't printing, cancel it, and let the other one's print. I read somewhere there is a 2GB limit on print spool jobs...and if you reach that limit, everything locks up. I am not sure on it...but if you have a realy large document, either print it alone, well, just print it alone. Try to spool your print jobs from the smallest ones first, and don't overload it. The is especially true of printing pictures...because if you don't resize them, they can be especially large files (and large pictures) sometimes you don't realize that what you are viewing on screen is only 26% of the actual picture size...especially if you have say, a 8MP or higher camera pixel size capability.
Jan 13, 2010 | HP Photosmart C4580 All-in-One InkJet...
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
My HP 1350v printer won't print. It appears to be
i bet it is but you could also try reinstalling the printer, setting it as default, making sure that when you send a request it is completely sent to the printer before closing the apllication. do this and you're in the clear
Oct 10, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer problem
Cancel all print jobs because most likley you have an error in a print job so cancel them shut off your printer turn it on nd try to print again
BestWishes                  -SunShine-
Jul 04, 2009 | HP LaserJet P2015dn Printer
Printer
spooling, is where the information being sent to the printer is being checked/converted for the printer driver , prior to being printed
Jan 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP Desk jet 3490
I requere drivers to install my printer 3940
Mar 08, 2007 | HP DeskJet 3940 InkJet Photo Printer
Cannot delete print job
click settings-control panel-administrative tools-services-select 'print spool' from the list-in dialog box click stop-and again click on start. Hope this solves your problem.
Jan 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet 3940 InkJet Photo Printer Logo
87 people viewed this question
Ben Johnson
