I'm looking to replace a fuser in a Sharp MX-7001n. I need the service manual and a source for the fuser. Thank you...
  • 12,061 Answers
Http://www.service-manual.net/ashop/catalogue.php?cat=281&exp=&resultpage=68&shop=1
Hi I have found a pay for link above, there is a service manual at the above website for download.
below is your spare parts.
http://www.precisionroller.com/catalog_display.php
Posted on Nov 12, 2010
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
Sharp MX-2600N has an error code C4-02 what does this mean
Hello Gail85,
According to the Sharp manual it says the following for error C4-02;
PTC heater open trouble
Causes
The PTU unit is not installed, or the heater line conduction trouble. PCU PWB trouble. Connector, harness connection trouble.
In other words, The fuser assembly has an open connection whether it is the springs on the ends not connecting correctly or most likely the PTC /Fuser assy is bad due to the heater filament is open needing the unit to be replaced by Sharp.
Good Luck!
Rich Lilja
Aug 08, 2011 | Sharp Office Equipment & Supplies
What is h4 02 fault means? Thank you.
You have an issue with one of the fuser thermistors.
You can try this.
Press in order # * C *. The diagnostics screen will appear. Then enter the number 14 as if making 14 copies, then start. It will then ask for fuser error clearance, Press 1 then execute then yes. Then press clear all a couple of times. See if it resets. If the problem continues you need to replace the thermistors that sense the temperature of the fuser rollers.
Jul 18, 2010 | Sharp MX-2300N Color Copier
When i start sharp- mx27004 printer then show problem is ''call for service code f2-40''
Hello.
Sounds like you need a service call. But, the tech should first check/inspect the Drum, Transfer Unit, and Fuser Unit and then reset your counter.
Hope this helps.
Apr 10, 2010 | Sharp MX-2700N Color Copier
Sharp MX-2300N with error code H3-00. . how do I fix it?
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Mar 09, 2010 | Sharp MX-2300N Color Copier
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
SHARP MX-3501N: The following Error Code is displayed on our unit. H4-00 Error; Call for Service. I need to reset the code, but do not know how
this error is a fuser unit error. you cannot reset the error code without repairing or replacing the fuser unit.
Nov 16, 2009 | Toshiba e-Studio162D Copier
What is Code: H5-01 on the sharp mx 2300 copier
You need a service reset.This is a fuser problem .clr and star and hash and star fusing reset
Oct 27, 2009 | Sharp MX-2300N Color Copier
k24674
