Question about Panasonic TC P42S1 42 in. Plasma HDTV
I have a panasonic tc-p42s1. TV won't turn on and the red light flashes 10 times.
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: panasonic th-42pz700u flashing red light 10 TIMES
pansonic th-42pz700u,red light blinks 10 times set wont turn on
Posted on Dec 04, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
  • 8457 Answers
SOURCE: Panasonic hdtv, TC-P42X1, no picture,
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
Blinks 10 times
Fan SOS is likely to be faulty. If you wish to get more details about the blinking codes to Panasonic Plasma TV, check the site linked below. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 07, 2013 | Panasonic TC P42S1 42 in. Plasma HDTV
Panosonic tc-p42s1 10 blinkes
This should help diagnose the problem.
Apr 04, 2013 | Panasonic TC P42S1 42 in. Plasma HDTV
TC-P50GT25 won't turn on
10 blinks check sc board for a short circuit in the mosfet ,replaces SC board
Mar 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
TV will not turn on. Red light blinks seven times in a cycle.
You're going to have to figure out which of the YSUS boards it is. They are on the left side of the TV when you have it opened up and on it's face. They are labeled SD, SU and SC. Try unplugging the SD, see if the number of flashes changes. If not, reconnect it and try it with the SU. If that fails to make a change, then unplug the SC board and see if it changes. This is an easy way to figure out which board is affected.
Feb 08, 2011 | Panasonic TC P42S1 42 in. Plasma HDTV
Is this a Plasma TV?
Yes.
http://reviews.cnet.com/flat-panel-tvs/panasonic-viera-tc-p42s1/4505-6482_7-33490462.html
excellent article that goes in detail about this specific tv, but yes deffinately a plasma.
Feb 07, 2011 | Panasonic TC P42S1 42 in. Plasma HDTV
My set just shut off and is now blinking 10 times.
What can possibly cause 10 blinks
A.Missing/Shorted F_15V
B.Shorted Vsus
C.Missing/Shorted SUB5V, SUB9V, BT30V.
D.IC1100, IC9003, IC9004
E.Unplugged SC20, SC2
F.Possibly SU and SD boards
Information from Panasonic.
May 18, 2010 | Panasonic TC P42S1 42 in. Plasma HDTV
Panasonic TC P42S1 42 in. Plasma HDTV Logo
350 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
