Question about Maytag Dishwashers
Water remains at the base of the dishwasher after each run and never clears. What can be done to fix this. Thanks, Jim Murphy
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Nov 12, 2010
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Dado
Jul 22, 2014 | Electrolux Dishwashers
My Bosch dishwasher has an E15 fault and is flashing check water
We read on google that a lady had this problem and we copied her instructions to see if it worked and am so pleased to say it did.
OUR PROBLEM WAS WE HAD E15 AND NO WATER IN THE BOTTOM OF OUR DISHWASHER, BUT THE PUMP STILL KEPT GOING ON AND OFF. EVEN WHEN THE ON/OFF BUTTON ON THE DISHWASHER WAS OFF.WE PULLED THE DISHWASHER OUT AND TILTED IT BACKWARDS (WHILST STILL ON), AND AFTER A MINUTE THE SETTING RETURNED TO NORMAL.So do try this before you call an engineer.
Feb 15, 2011 | Bosch Dishwashers
The dishwasher has been working perfectly until recently it's not draining and water is remaining in the basin of the unit.
need to be sure the filter in the base of the dishwasher is clear of anything that would keep it from draining such as a screen filter. also need to check the hose that drains to the sink is clear. from there it is most likely a pump or timer issue.
Dec 17, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Is a small pool of water in bottom after dishwasher has finished
check the air gap for the blockage,or the underneath of the pump screen
Jul 31, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenwood dish washer showing E4
Check the water inlet on the top of the dishwasher isn`t loose. It`s an easy fix if it is, just hold the inlet on top where the hose goes in and hand screw the plastic cap underneath thats inside the dishwasher. Mine done this and the water was pouring down from the top into the base, just follow the other tip for emptying the water from the base
Apr 23, 2010 | Kenwood KDW243A Builtin Dishwasher
When we start our 18inch portable dishwasher clear water comes out from the bottom. what could be the reasons? thanks Jim
sounds like the seal under the motor has dried out or is damaged dishwasher must always have water in the bottom to keep the seal moist or they dry out and must be replaced the seal is located in the centre bottom of the dishwasher inside machine just above the motor
Dec 15, 2009 | Kenmore Dishwashers
Bosch shx33a issues
sounds like the float is up and unit is in drain mode.if its only humming that is the problem. there is water in. the base.take off side panel and reach in the base with something to dry the bas out. normally this is caused by a leaking hose. if this doesnt fix problem post the question follow up. thanks
Nov 21, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Water does not drain after the wash/rinse/and dry cycle
You don't list the make and model of the dishwasher, but generally,when an older dishwasher is not fully draining and the remaining water is not clean, the wash pump motor is failing.
But first check the drain hose from the base of the dishwasher clear to the drain. Make sure the hose is not obstructed. If that hose connects to a disposal, check closely the drain pipe on the disposal.
Good Luck!
May 05, 2009 | Dishwashers
Water stay in .
Please post back here what the manufacturer and model number of your dishwasher.
Also, approximately how many years old is your dishwasher?
Can you be more specific with your problem?
If water remains after the cycle is done:
Is the water clear/clean?
How much water is left? More then 2 inches?
Please post back here with your findings, OK?
Apr 16, 2009 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
