My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are identified as VIA High Definition speakers. if you know where and how i can get updated drives, or think it is a different issue, please let me know.
  • 27,725 Answers
Control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Posted on Nov 11, 2010
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
My lap top has stopped playing audio
Right click the volume control - select open - this will open a larger volume control showing the volumes for each type of sound. Make sure none of the sliders are muted or low.
Apr 20, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Sound is not working on my hp laptop
I had the same problem; my laptop's speakers suddenly stopped working but I could still use the headphones and sound was fine.
I played around a while and searched the net; and I got them to work:
Open Control Panel- Sound, Speech, Audio Devices-------->
1) Audio Tab
2) Under 'Sound Playback' hit Advanced
3) At the bottom where it has Speaker Setup change it to "Laptop Stereo Speakers" (mine was initially on "Desktop Stereo Speakers" for some odd reason)
Problem solved, Thank God (Alhamdulilah)!
Hope it works out for you :)
Dec 04, 2008 | HP Pavilion dv6000z Notebook
No Sound
Since it is still playing audio, just not on the laptop's speakers, then likely your speakers have gone bad. They are replaceable but sometimes getting to them can be a pain as well as finding another set of speakers for it.
Jun 22, 2008 | Gateway MT3705 Notebook
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Setup,check & instulation problems
What type of sound card do you have? Just play some music and see how it sounds. There are audio tests, but they're all pointless as they do nothing more than play music and frequenices your laptop speakers can't handle. Some ways of testing I suppose would be running 'dxdiag' in the Run prompt from the Start menu, click on the 'Sound' tab and test it...there are some additional options in the Sound Control menu accessed from My Computer.
Sep 14, 2005 | IBM (2371E9U) PC Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
