Question about Cabela's Cabelas Pine Ridge 3 X 9 X 40 Rifle Scope
I bought a Pine Ridge 3 X 9 X 40 Rifle Scope out of Bargain cave and on the ajustment are gaderated for the 22 hornet i want to use it on a 3006 can get get the ajustment for the 3006
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: got moisture in scope and it is fogged up
take it into a camera shop, they will have the tool,, but if you undo the scope it will need to be regased again the "o"ring seals have worn out or broken and thats how water got into it,, it also let the nitrogen out of it,,,if its a cheepy scope buy a new one,,,
what i mean by a cheepy is less than £1000,,,,
Posted on Nov 17, 2009
agent91
  • 2100 Answers
SOURCE: I just purchased a savage .17 HMR with a cabelas
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
Posted on Mar 09, 2010
Have a pine ridge rimfire scope need to know what mounts i need to atttach to a marlin 60
1 inch dovetail mounts medium height if your marlin 60 has 11 mm dovetail rails . if not will need to get receiver drilled for rail mounting and mounts of your choice better to get a competent gunsmith to do it
Jan 18, 2014 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Gamo Hornet schematic
The best thing to do is go on the internet and type in the company name.And see if they have what you need.Or maybe they can tell you who to contact for the schematics and directions to assemble it together.Hope this helps you out.Joseph A Bagli.
Jan 29, 2013 | Caliber Gamo USA Hunter Elite .177 Air...
I dont understand what the extra dial on my new 6-18x44 scope is for or how to use it.Or what range evry line and dot in the reticule should be ranged in at.
The third turret is for parallax and approximate range
And the lines on the reticule are round and velocity specific plus magnification comes into the distances between substension
On my scope 100 yard zero the next substension down is 176 yards at 10 magnification
The best way to use the reticule for ranging is to get a ballistics program and enter rifle round and scope stats and get a chart for that round and reticule
And the drop chart will change for different velocities and ballistic coefficients of rounds and temperatures a summer chart will be different to a winter chart due to denser air in the cold
Apr 14, 2011 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Which knob you adjust for drop? What is the left knob for?
If you have 2 knobs, there should be no left knob. If you have a knob on the left, you have it mounted 90 degrees out of alignment. Loosen the rings and turn it 90 degrees clockwise. Once you do that, the knob on the top is the one you will use for elevation.
If you have 3 knobs, the left one is for parallax adjustment, focuses the scope for specific ranges. the top knob is the elevation adjustment in this case also.
Sep 20, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I just purchased a savage .17 HMR with a cabelas pine ridge 3x9x40 tactical scope and I'm having problems siteing it in. It is shooting aout 4 inches low regadless of adjustments I try and make.
Mar 07, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I have to use reading glasses to use a simmons blazer rifle scope.....othewise the image is blurry.
You can't see the cross hairs or the whole picture is blurry? I know that the rear ring on the scope will bring the cross hairs into focus, glasses or not, and the scope itself should be clear all the way down, I can't see a thing either without glasses and it has really hampered my shooting. It ain't no fun , it's frustrating. Try turning the rear eyepiece, see what happens, hope this helps.
Feb 27, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Got moisture in scope and it is fogged up
Nov 16, 2009 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Rifle scope is hitting 5 feet high but dead center
mounts are probably too high.....had the same prob on a .22 rifle with high mounts for open site shooting also. i bought a lower mount and zeroed it in with no prob
Nov 24, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Cabela's Cabelas Pine Ridge 3 X 9 X 40 Rifle Scope Logo
29 people viewed this question
Top Cabela's Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Cabela's Optic Expert? Answer questions, earn points and help others
