Question about Hauck ICoo Targo Stroller and Pram - Mocha Standard
Could you tell me what the pins are called that hold the wheel on and where i could buy them from?
I lost a pin for the right knob that help out with folding so my icoo stroller doesn't fold. Can you tell me where to buy the parts. Home depot doesn't have that size screws and pins.
Posted on Jun 14, 2012
    Guru:
  • 541 Answers
Pins? I don't know your model but most stroller prams use Capped Starlocks if its a pin with a looped top and spits in two at the bottom it's a cotter or split pin. any hardware can help with those. Any thing else is a custom part and a problem.
http://www.bakfin.com/starlock/starlock-sample-box.html
Posted on Nov 12, 2010
How do I change back tire on a Toa Toa 50 cc scooter?
A single bolt with a cotter pin holds the rear wheel on the axle, covered with a plastic dust cap. Remove the cap, Remove the pin, then use a pry bar to hold the wheel in place while you undo the axle nut. Once removed, tap the end of the axle with a rubber mallet or use a piece of wood and a hammer until the wheel comes loose. Remove, use motorcycle tire tools to remove tire, replace tire, and remount wheel. Use a new cotter pin.
Sep 28, 2014 | Motorcycles
How will towing a new 5th Wheel with 1994 7.3L IDI (non powerstroke) Turbo Diesel be?
You have plenty of truck to tow that thing around. I would have the 20 year old tranny serviced and ask the transmission shop if its going to hold up to the pressure.
May 04, 2014 | 1994 Ford F350 Crew Cab
How do i remove an ignition in a gmc jimmy 2000 without a key?
Hello, Dan. First, disconnect the negative (-)/ground on the battery Dan are you mechanically inclined. If not then don't attempted this job.
You will need to remove all the plastic covers on the steering column. Remove the horn ring.--two screws under the steering wheel. Remove the horn ring and disconnect the horn plug. Remove the steering wheel nut. Use a steering wheel puller to remove the steering wheel.
Remove the turn signal switch that fit around the upper part of the steering column. Then remove the some of the parts that are associated with the steering wheel and/or column.
Now, look at the ignition switch flange, it a big chunk of aluminum. Now look for a large aluminum dowel pin 5/8" in diameter that is driven into the chuck of aluminum but it is parallel to the steering column.
This aluminum dowel pin will have to be drill out before you can get ignition housing off, If there is adjustable steering column lever, remove this also.
Now, once the dowel pin has been removed, looking for a **** in the ignition housing. Take chisel and insert into this ****, drive the chisel into the **** until the ignition housing is loose to be remove by sliding it up over the steering column.
If you buy a new ignition switch, on purchase the switch with keys. Don't buy the hole new ignition housing.. If you do it will get expensive.
In the ignition (old) housing drive out the ignition switch pins that keeps the ignition switch in the housing. Install the new ignition switch re-insert the ignition switch hold pins.
I am fairly sure that Carquest/ NAPA some other larger auto parts will have ignition housing bolt. If they try to sell you a replacement aluminum dowel pin don't buy it. It is almost impossible to install the aluminum dowel pin without the proper tools, so use a bolt to squeeze ignition housing together.
Before putting everything back together. Now, check the new ignition switch to make sure it works. I wish you lot of luck. GB...stewbison
Sep 27, 2011 | 2000 GMC Jimmy
How do you replace the ignition lock cylinder for a 1972 Corvette? The cylinder is stuck in the lock position and even with the key inserted it will not turn, thus locking the steering wheel and vehicle in...
Try and turn the wheel from side to side while turning the key as it may be jammed on the locking pin... If that's a no go then you must remove the steering wheel and signal switch to access the screw that holds the cylinder in place. If you must remove the wheel go to a parts store and buy a lock plate installer to remove the circlip that holds the lock plate compressed.
Jul 28, 2010 | 1972 Chevrolet Corvette
In the rer where the driverside wheel is when u remove the tire there is a long bar that holds the tires in place. there is also a small bar just underneth it it snap and my wheel is moving forwar and...
If you are talking about what I think you are, I always called that the lower A-arm. It holds the wheel assembly in position as it goes up and down.?
Im so bad with names I probably shouldnt even have tried to answer this, lol but it is a place to start.
Mar 11, 2010 | 1993 Saturn SL2
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Cotter pins to hold rear wheels in place--Emergency !!
you shouldn't have to pry them apart most cotter keys should drive staight in
Aug 21, 2007 | Cosco Deluxe Comfort Ride 01-834 Stroller
Hauck ICoo Targo Stroller and Pram - Mocha Standard Logo
171 people viewed this question
Top Hauck Baby Gear Experts
Kelley Hopper
ray gallant
Dorel UK
Dorel UK
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
