Question about Crosley W.C. Woods DCW40S Electric Dehumidifier 40-Pt. Dehumidifier
Kenmore electronic 40 model c675-25024-0j needs new board the switch on board klick on and of very fast.
Zd30 year old does nothing !
check the fuse on the pcm board. 3 amp fuse. will need to open the unit up to get to it.
Oct 25, 2013 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
The dehumidifier runs but no waster is coming out
Frank it sounds like to me that it needs to be shut off a while, Was there a power outage or did you happen to shut it off and try to restart it real fast. If so then the compressor can not push the freon through. let it sit for about 8 to 10 minutes so the pressure drops and then restart it. Otherwise it will just burn up the compressor
Jun 20, 2009 | Kenmore Dehumidifiers
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Apr 21, 2009 | Haier HDN305 Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Kenmore model # 25800-25801 Error code E3 ?
You can try cleaning the humidity sensor, which is on a circuit board
housed in a nylon clip attached to the cooling coils.
The sensor is in a plastic clip, which can be opened up and cleaned.
Some report success. Didn't work for me.
I ended up rewiring the unit so that a 5v control
line from the lower relay board goes through the SPDT bucket full switch,
turning on the control board when full (so it beeps), but otherwise
enabling the compressor and fan. The fan and compressor
are controlled by relays, which are driven by a ULN2003AN
relay driver. I fed the empty side of the full bucket switch back into
the relay driver to turn on the compress and the fan on high.
I plan to put a dehumidistat in series with this control line;
now it just runs till the bucket is full. A Broan DH100W dehumidistat
is 20 bucks. Could also put in a rotary switch to control the fan speed,
but for me high is enough.
I think this machine is made by Goldstar for Kenmore and Delonghi.
Stuff is just made to break and through away these days, which is a shame.
Jun 03, 2008 | Kenmore 53701 Dehumidifier
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Fan not working
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Mar 22, 2008 | Kenmore 54501 Dehumidifier
Kenmore model 580.54701 70 Pint dehumidifier
Evaporator fan is not turning on - a problem with almost all dehumidifiers... probably on this unit (being so new) it's the control circuitry (in the circuit board) which switches the fan on...
I have the same unit with the same problem)
Sep 07, 2007 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
132 people viewed this question
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
