Question about Belkin Computers & Internet
What is my routers ip adress? - Belkin Computers & Internet
  • 1,679 Answers
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Hope this is helpful.
* Rating and comments are welcome on this solution
Posted on Nov 11, 2010
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
My ip adress is gone of laptop how do i fix it
Normally IP Address is assigned by your router which then also provides gateway and dns settings. On the IP address screen, select Obtain automatically for both IP and DNS.
If this does not solve your problem, please explain fully what the problem is.
May 12, 2011 | ip-adress.com
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
Check IP adress, Sub-net Mask and Gateway adress
open rum command and type command ......
after open command prompt ....
type ipconfig and enter......
ok
you see your ip address subnet...
Sep 02, 2009 | Linksys WCG200 Wireless Router
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Belkin Router
Ip adresses are SIMPLE to find, it doesn't matter what router you have, unless you are looking for local ip which doesn't seem you stated it
You could find your ip in theese following sites
www.ip-adress.com
www.ipchicken.com
www.whatsmyip.org
www.whatsmyip.net
Hope this helped!
Dec 01, 2007 | Belkin (F5D5231-4) Router
Port Forwarding - can't access router management
normaly you can gain entry to the router
via an ip adress you would put into internet explorer
you can get the ip adress from the manual you got with the router
failing having the book then a google serach will tip up the info you need
Nov 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
