Question about Kodak Easyshare CD82 Digital Camera
My lens won't open and it says it has a lens error:111
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 11, 2010
Lens error 111
ALSO, please see this link for further troubleshooting steps for a lens error.
May 01, 2013 | Kodak Easyshare C813 Digital Camera
Dropped camera in sand...
Your best bet is to just open it up and try and blow the sand out but you will want to be very careful.
Hope this helps.
Thanks,
Lee
Jul 15, 2008 | Kodak EasyShare C743 Digital Camera
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
The camera says lens error 111 what do i do to turn it on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try.
May 27, 2011 | Kodak Easyshare C813 Digital Camera
When I turn camera on lens error 111 shows up on screen and goes right off and lens does not come out
Make sure all the moving parts of the lens are free to move. If you dropped the camera or spilled something sticky on the lens part, it may be stuck and the camera cannot turn on.
Try this at you own risk:
1. Try jiggling the lens with your fingers while turning on the camera, helping it to pull out.
2. If there is something sticky keeping the lens from opening, try to use a warm damp cloth to dissolve it.
3. If nothing works, bring it to a repair center. You may also try the solutions provided in this other fixya article.
Mar 23, 2011 | Cameras
Error 111 what the ****
It is Lens open time out error. Your camera lens is jammed or bent. Try re loading battery. If not resolved go to service centre.
Dec 24, 2010 | Kodak EasyShare CX7530 Digital Camera
How do i fix the lens error 111?
for me when i was getting the lens error 111, the lens shutters were set crooked and was able to move them slightly and the error went away and the camera works fine now.
Nov 01, 2010 | Kodak Easyshare CD82 Digital Camera
Coolpix nikon camera lens error
as you have only had this for 3 months it should still be within warranty,
approach the place you purchased from for a warranty repair / replacement
Apr 24, 2009 | Nikon COOLPIX L3 Digital Camera
Lens error 111
thats ok... but i will need other details like the make and model as well as date and place of purchase please...
Thankyou
Aug 13, 2008 | Kodak EasyShare C633 Digital Camera
Kodak Easyshare CD82 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
