Question about HP Photosmart C5180 All-In-One InkJet Printer
My HP C5180 was making crcking & grinding noise but printed. Then I received the 'ink system failure' and briefly once a pump failure. Now the printer just turns on & off by itself. I cannot shut of the machine unless I unplug it.
  • HP Master
  • 11,800 Answers
The cracking and grinding were caused by the belt of the printing head carrier forcing itself to dragging the head on the guiding rails. The only thing that would cause that is a blockage on the rail and the only 2 things there are the data cable or the loom of ink pipes to the printing head. Since you got an pump failure then it must be the pipes - they got caught and ended up being ripped apart, depriving the printing head of ink, causing it to overheat and probably fail hence the ink system failure.
The entire system will have to be replaced, this can be done only at a HP service shop and it's going to be very expensive - certainly more than what the printer is worth, maybe even more that the price of a new one.
This printer is dead, time for a new one.
Posted on Nov 12, 2010
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Error ink system failure on photosmart c5180
The "ink system failure is a common error on HP printers, it is caused by air in the ink cartridges or ink feed tubes. YOu will need to do a ink purge routine to clear the error. We have several pages on our web site explaining what causes the problem and how to clear it. The link is: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
This should get you up and printing in no time at all.
I hope this helps you, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
196 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
