Question about Goodman GMS90703BXA Heater
Hello I have a 2007 goodman and the light blinks once it sais lock out on the door what does that mean I cant find my manual
  • 407 Answers
Lock-Out happens when the unit tries to start and fails after three consecutive attempts. Usually it's the flame sensor or the igniter. Its best to be in front of the unit while it attempts to start to see which component is not working. It will be in this order- The induction motor comes on, then the igniter which will be the glow you see, then the gas valve opens and flames start. If the flames never start, the igniter is bad, if you get the flames, but then the click back off, you probably have a bad flame proving rod, which is located in front of the burners to one side. You can clean these to get them to work most of the time. Just use a lite abrasive material and clean the rod. Be sure to shut all power off before doing so. Hope this helps and good luck!
Posted on Jul 03, 2011
Furnace fails to light after. 3 attempts then LOCKS out, will come back on after 1, hour.....only does it once in a,while... One,blink. Goodman dependable ninety two
What is the blinking code ,check on your door cover and you will see code and fault.This should lead you to the problem
Feb 08, 2018 | Goodman Heating & Cooling
Gas dose not come on
The blinking light is giving you a trouble code for the unit. It should have a label or something inside the unit or in your owners manual to let you know what the code means. Count the number of blinks. It should repeat over and over.
Jun 06, 2010 | Goodman GMS90703BXA Heater
Goodman furnace fault light blinks 3 times it kicks on but does not blow heat?
Hi, what you have to do is where you see this light flashing, there is a circuit board. Remove the panel. If everything goes black, you have a door switch on the perimeter that you can tape down to restore power to the furnace. On the panel, you will find a error code sheet glued on it telling you what the flashes mean. 3 flashes may say you have an open pressure switch, or 4 may say the inducer motors off or something else. It will almost troubleshoot itself. Find out what the 3 flashes mean and if you cant figure out what to do, contact me and I will walk you through it. It sounds like you have a dirty flame sensor, or an intermittent problem in the ignitor module. Check it out as it will tell you.
Sincerely,
Shastalaker7
Feb 25, 2010 | Goodman Heating & Cooling
I replaced the battery in my 2007 volvo s40 2.4i, and the alarm light blinks, but nothing else works. The key isn't working to open the doors and turn off the alarm?
Hello! Tell me Is the hood open or closed? Do you have a spare door key?
If the doors are locked, the hood is closed, your key will not unlock the doors, and neither will your spare...Your going to need a locksmith...
Send a comment with a full description as to what happened and I'll attempt a fix...........Guru...........saailer
Feb 24, 2010 | 2007 Volvo S40 2.4i Sedan
I have a Goodman GMPN080-4 furnace. The light on the board blinks 3 times. The furnace won't light at all. What could be the problem?
Hi 3 blinks should mean it is the pressure switch there should be a code in the manual or inside of the door
Jan 30, 2010 | Goodman Heating & Cooling
Three blinks - what does it mean
The safety limit inside the blower section has tripped.
Oct 31, 2008 | Goodman GMS90703BXA Heater
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
