Question about LG Goldstar LD65EL Dehumidifier
My dehumidifier was running fine then it just stopped filling with water how can I fix this
  • LG Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Our AD25THO. Runs fine but has recently stopped collecting water. It's dry as a bone and our basement is very damp. What's wrong with it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 11, 2011 | Whirlpool AD25BBR Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
My DD50E has stopped collecting water and filling up. It runs but doesn't collect water.
heatman101
Feb 17, 2011 | DeLonghi DDE50E Dehumidifier
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
If my dehumidifier seems to be working fine( fan comes on and all buttons work) and its not picking up water anymore could there be some other reason that its not filling up? We did also fix a few leeks in...
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Frigidaire FDL50R1 Dehumidifier
My dehumidifier runs but never fills up. All of a sudden just stopped working.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Aug 10, 2010 | Whirlpool Dehumidifiers
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
129 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
