Question about Panasonic Cameras
When I turn on my lumix 12x DMC ZS3 it says "memory card is locked" what do I do? Thanks
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 11, 2010
I have Panasonic DMC-ZS6 Lumix w/4gb memory card - has worked fine until today- now window says
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
MEMORY CARD IS LOCKED
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 05, 2012 | Panasonic Lumix DMC-ZS3 Digital Camera
Panasonic lumix dmc tz7 has message no valid picture to display. Can someone please help? This is not a new memory card , it has been in use for a few weeks.
Have you got the switch on the rear of the camera set to camera and not playback? My camera displays this message if I have no images on my memory card and try to play them back.
Nov 29, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Cannot get the pictures to record on the chip rather than the internal memory card?
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory and then promise to never use it again.
Oct 21, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
Apr 22, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
I just need a user's manual for a Panasonic Lumix DMC-ZS3.
Go here:
http://www.dphotojournal.com/panasonic-lumix-dmc-tz7-zs3-review-samples-user-manual/
And click on the "manual" tab.
In reality, this is trivial to find, if you just type into google:
Panasonic DMC-ZS3 Manual PDF
It pops almost to the top. Probably would have been less effort than putting the question up here ;)
Aug 19, 2009 | Panasonic Lumix DMC-ZS3 Digital Camera
Lumix dmc fs3 troubleshooting - memory card is locked
Take the card out - on the side there is a little white slider with a locked & unlocked padlock symbol - move it to the opposite position it is in now.
Nov 06, 2008 | Panasonic Lumix® DMC-FS3 Digital Camera
Cameras Logo
173 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
