Question about Cars & Co Cars and Co 196070s Prefo Dresden Rare Skoda Truck Slot Car Pair
I HAVE SKODA SUPERB COMFORT 2003 THE INSTRUMENT DISPLAY AND INFORMATION CLUSTER ALL WORK BUT THE DISPLAY AND ALL THE DOORS HEATER RADIO ILLIMATION LIGHTING HAS GONE OFF HAS ANYONE HAD THIS HAPPEN TO THEM THANK YOU FOR YOUR TIME STE PS THIS HAS HAPPEND AFEW TIMES
    Champion:
  • 206 Answers
Had same fault...replaced dashlight dimmer switch, all ok
Posted on May 29, 2011
My speedometer works but my digital odometer does not work on my 2003 old alero
This is one guy's advice: Replace the speedo head, that should take care of the problem."
This site is also interesting because the guy said
General Motors cars had instrument cluster problems from 2003 through 2006. When I researched instrument cluster problems on the Internet what I found raised concerns in me. Many of those vehicles had problems that began with the instrument cluster, but eventually led to the engine refusing to start.
(an electronic instrument cluster, digital instrument panel or digital dash for short, is a set of instrumentation, including the speedometer, that is displayed with a digital readout rather than with the traditional analog gauges. Many refer to it simply as a digital speedometer.)
http://www.instructables.com/id/Erratic-Instrument-Panel-on-GM-Cars/
Feb 12, 2017 | 2003 Oldsmobile Alero
How do i remove my radio unit from my skoda superb 2010
should use special tools two p.c . throw two hole of luck at radio panel
Sep 12, 2012 | Skoda Superb Cars & Trucks
Fan/motor clicking noise with my Skoda superb 2003, 2.5L
Yeah there is a fuse under the dash board on the driver side. But if you take it out your heater and air conditioner want work. you can remove the dash panel on the passenger side and oil the blow motor and it will not make it noise.
Jan 25, 2010 | 2003 Volkswagen Passat
Hi I have a skoda superb(2003),when I unlock the car or no matter which door I open,cabin light,door lights,side mirrors lights,boot lights don't work.Fuses and relays are ok,what should I do?
check that the drain hole for the windscreen wipers is not blocked. This can cause water to ingress into the front passenger foot area. There are electrical connections under the carpet area. Sort these and your problems should be over.
Jan 12, 2010 | 2003 Volkswagen Passat
Radio reading locked on 2003 monte carlo
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Monte Carlo instrument cluster repair
Jul 29, 2009 | 2003 Chevrolet Monte Carlo
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Jul 09, 2008 | 2003 Volkswagen Golf
Cars & Co Cars and Co 196070s Prefo Dresden Rare Skoda Truck Slot Car Pair Logo
235 people viewed this question
Top Cars & Co Toys Experts
Adam Fjeld
Adam Fjeld
Tom Chichester
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
