Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Water is clogged in the bottm of the unit. how do I clear the drain?
    President:
  • 1,140 Answers
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
1. Blocked drain filter
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
Posted on Nov 11, 2010
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
Drain plug on a 2002saab a\c unit.
All A/C units drain water and need a clear path to drain water. If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree. If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Show Less I hope this info helps Russell.
Jul 12, 2016 | Cars & Trucks
Jthe water from the defrost cycle doesn't drain into the pan underneath. It freezes up and runs into the bottm of freezer until it must be defrosted on the bottom only.
The defrost drain which is behind the evaporator wall becomes frozen over or blocked by debris. You must remove the back wall to get at the drain and thaw it or snake it with wire to free the clog. After its clear, wrap some copper wire around the defrost heater and drop a length of it into the drain hole. This will prevent it from freezing over again.
Jul 28, 2014 | Whirlpool Refrigerators
Why does frigidaire mrs26lgj side by side redfrigerator have water/ice in the bottm of the freezer
Hello - Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. Should this suggestion prove to be ineffective contact a professional to properly diagnose the refrigerator.
Oct 19, 2012 | Frigidaire Refrigerators
There is water in the pan in the attic of the York 80 unit. The drain line that goes out from the unit, outside appears to be clear. What next?
The condesate drain is clogged, most of the time they clog at the trap close to the furnace.You need to clear the clog and clean the drain line and drip pan if you can get to it.
Jun 19, 2011 | Heating & Cooling
Standing water after nonuse
You need to clean out the drain pump. usually located at the bottm fron of machine. clogged drain pump = standing and very stinky H2O.
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
My Air conditioner leaks water
Aug 02, 2009 | Kenmore Heating & Cooling
Water is leaking from the bottm
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Refrigerators
4.0L 6cyl doesn't have a rubber plug in drain housing
clear the ac condensation drain under the car on the bottm of the passenger side eng firewall.
Jun 29, 2009 | 1998 Jeep Grand Cherokee
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
118 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
