Question about GE WBVH6240F Front Load Washer
My washer is in locked mode. No other buttons will worked. I've unplugged for overnite and still when plugged back in, it still says doorlocked.
  • Cindy Fehrman Jun 17, 2008
    My washer is a front loading GE, I believe it is Model WBVH6240. I was also having problems getting it to drain properly, took hose off and no obstructions.
    Now, it's locked with wet clothes inside
  • blur_29_33 Jan 30, 2009
    Same problem with cloths and water inside.
The only button that works on washer is the lock button. It seems that the keys are locked
Posted on Nov 23, 2008
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
Aug 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The Samsung washer (Top Loading) WA80V3WE not switching on and water drains out continuously. The display shows time 22 and I ve selected quick wash mode and extra low water level. I ve checked the child...
if water just keeps draining check the drain hose,if it's down to far into the stand pipe the water will just keep siphoning out,if that's ok,when it starts let it run for the first two minutes and then it should reset and start,also try unplugging it for like 5 to 10 minutes and plug it back in,that will reboot the computer board.
Feb 09, 2018 | Washing Machines
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Door wont lock so it's not spinning
replace the doorlock instructions come in kit
Dec 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
GE WBVH6240F Front Load Washer Logo
193 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
