Intruder alarms im looking for wiring diagrams showing me the connections for my texecom odyssey 1e bell box to my veritas 8 control panel, to link them so that they work together
Hi Sparky79,
Please find notes below should they help.
12v - 12 volts supply (+)
0v - 0 volts supply (-)
TR - Tamper return from bell
B - Bell Trigger
ST - Stroble Triger
For every car ever made in the history of motor cars Karen? :>D
It doesn't really work like that. The electronic windows have a fuse, but things like central locking and the alarm are controlled by the Body control Module.
'year make model' in all questions please, first 3 words.
There are over 40,000 categories listed by 'make year model'.
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
its a long time since i worked on these but its quite easy you want the 2 terminals that make a circuit when the magnet is placed by the switch and breaks the circuit when the magnet is removed.hope this helps
les from new zealand (ex uk)
Your manual is available from Texeco: CLICK HERE.
The Veritas 8 Compact is on the top line. You can also get the installation manual or a sales brochure from there.
To change your code:
Enter Existing Code
Press Prog
Press 60
Enter New Code
Press Prog
Press Reset
