Question about Lexmark X364dn All-In-One Laser Printer
I have a lexmark x364dn. It has a line through the copies I make. I can print and scan and it is fine. The line is just on copies
    President:
  • 1,082 Answers
Assuming the COPY uses a automatic document feeder. The doc feeder scans doc by passing doc over a narrow window. If there is a dot or several dots in the narrow window, it / they will show up on copies as a line.
Clean the window (looks like a long glass window about 1 inch wide ) carefully with a SLIGHTLY damp towel. Should get rid of the lines.
Posted on Nov 11, 2010
Lexmark p4350 copy has two horizontal lines on page- clean glass
It could be due to some dirt on the scanner glass. Try to wipe the glass with a lint-free cloth.
Then, try to scan again to verify that the problem is fixed.
Feb 21, 2012 | Lexmark P4350 All-In-One InkJet Printer
We have a lexmark X364dn printer/fax machine and are looking for the location of the serial number
Can you use the buttons and LCD display to print a "test-page" ?
Often, the "test-page" shows "everything", such as percentage of toner remaining,
number of pages printed, model-number, and serial-number.
Jul 19, 2011 | Lexmark X364dn All-In-One Laser Printer
I have a Lexmark X364DN and would like to change the default paper tray for incoming faxes.
1- Go to Fax Settings menu
2- Under Fax settings menu, look for Fax Receive Settings
3- Under Fax Fax Receive Settings, look for Paper Source
4- Under Paper Source You should find three options: Auto (default), tray <x> (the tray number you want it to print from), or manual feed.
Change according to your preference.
Hope it helps!
Jun 21, 2011 | Lexmark X364dn All-In-One Laser Printer
How do I set up the fax auto answer on my Lexmark x364dn? Just started a new job that is very fax-centered, and I cant get my fax to auto-answer! Hooked up thru a GE phone/answering machine, no...
The factory default setting of the printer is set to auto answer, please sure that the connection between the fax machine and answering machine is properly connected. Please click on the link http://bit.ly/qCaWn8 to view more information.
For more information, please contact Lexmark Technical Support.
Mar 24, 2011 | Lexmark X364dn All-In-One Laser Printer
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark 5075 - vertical line on copies or scans only
Clean all glass with 70% isopropal alcohol on the scanner. If the line is perfectly straight and crisp. There a spec on the glass probally causing the line.
Feb 21, 2010 | Lexmark X9575 InkJet Printer
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Lexmark X364dn All-In-One Laser Printer Logo
368 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
