Question about Saeco Classico Espresso Machine
The water does not get got enough. I replaced the thermostat, it did not resolve the problem. The water is still warm.
  • bansheracer Nov 12, 2010
    Will it steam?
    Problem Solver:
  • 11 Answers
Did you replace the 95 deg thermostat or the 127deg thermal switch ?
Normal temperature control works like this, you turn on power and the boiler heats up. When it reaches 95 deg the thermostat will open and turn off power to the boiler, when it then cools down a little the thermostat will close and it will heat up again.
If the thermostat should fail in the closed position the boiler will continue to heat past 95 deg until it trips the 127 deg thermal switch which is a safety feature.
In your case maybe the 127 deg thermal switch is faulty and opening earlier than the 95 deg thermostat.
Posted on Nov 21, 2010
  • Graeme Scott Feb 22, 2011
    My description above is not correct.
    It's the 127 thermostat switch that controls the heat to the boiler. I'm not sure what the 95 deg switch is for. Maybe it won't run the pump unless it's above 95 degrees. ?
Water is not getting hot enough
thermostat set too low.
leak in hot water line or hot water being used too fast.
defective thermostat
Dec 09, 2014 | Reliance Water Heaters
Why isn't my heater in my car getting warm
There could be several reason. The water pump could be weak. The radiator could be low on Anti freeze. The control valve on the heater line from the motor could be malfunctioning. The thermostat could be bad. You may even have an air bubble in the system that is causing the problem. The only way to be sure is to test each are. Check the fluid level and make sure it is good then run the vehicle till it warms up. With the vehicle running and warm locate the control valve on the hose running from the motor or radiator to the firewall, there are two. One will have the valve on it. You can open this valve manually and see if that allows the interior to warm up. If it does then the controller and vacuum lines to that valve. If it doesn't then remove the thermostat and see if that resolves the issue. If that doesn't resolve the issue replace the water pump.
Oct 13, 2011 | 2002 Mitsubishi Eclipse
My 03 plate kia sedona 2.9 will not get warm no matter how long you drive it for any ideas what the problem is please
This could be a sticky thermostat or faulty water pump, the thermostat is the cheapest to resolve so i would try this first more than likely it will be the water pump needs replacing
Hope this helps
Steve
Mar 02, 2011 | Kia Sedona Cars & Trucks
Over heating
Thermostats in cars are often neglected, if not totally forgotten, units. Yet they play an important role in the general performance of cars by restricting water flow until the engine has warmed-up. Thermostats are heat sensitive valves that open and close. On cars they prevent circulation of coolant to the radiator until the engine is warm enough. When the thermostat is closed water only flows through the water pump and water jacket to let the engine warm quickly. When the thermostat opens, water can then pass through the radiator for general cooling.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Having a car that warms quickly is particularly useful in cold weather when you want to use your car heater as soon as possible. The thermostat is in a small housing positioned where the top radiator hose connects to the engine. The best time to check or change a thermostat is when you are servicing your radiator because you need to drain the cooling system
first. Hence, a thermostat change is a good time to flush and clean your cooling system, check all radiator hoses and the radiator pressure cap. Be sure you have the correct cap on your radiator and it is not rusted. Thermostats are small, inexpensive items. You can test them by heating in water and checking their operating temperature with a thermometer. However it really is quicker and ultimately more reliable to simply fit a new one,
1. thermostat common problems (replace every 50-60k miles)
2. thermostat switch sensor (which turn your cooling fan on and off)
3. check and see if the cooling fans is running when the engine get to its operation temperature. (fan motor can be fault)
Dec 01, 2010 | 1997 Cadillac DeVille
I can't seem to find the thermostat in my 2000 Chrysler LHS 3.5 L Is it in the manifold at the end of the upper radiator hose or elsewhere? I've seen so many answers and haven't yet found a solution. A...
If you were to take the upper radiator hose off the engine, and look into the resultant hole, you would see the thermostat.
The thermostat on all cars blocks water leaving the engine and going to the radiator, until the thermostat warms up enough to open.
While the thermostat is closed, water circulates through the heater hose, straight back to the inlet of the water pump. This circulation prevents hot spots, distributing the heat evenly to warm the engine up, and also brings that warmed water to the thermostat.
When the t-stat gets hot enough to open, water leaves the engine instead of circulating through it, and that allows cool(ed) water to flow from the radiator through the bottom hose to replace the water that left through the upper hose and t-stat.
The stub that the upper hose attaches to on the engine should be part of a small housing that is bolted to the engine. Removing that housing is how you remove the t-stat.
Aug 05, 2010 | 2000 Chrysler LHS
My car was overheating so i took off the thermostat and replace a hose that was leaking but now car hasn't overheat yet b water comes out through reservoir tank what could be the problem now?
the water is getting to hot even though its not overheating because you need a thermostat to trap the water in the radiator to give the water a chance to cool down then the thermostat opens and the cold wanter enters the motor and the hot water in the motoer enters the rad. to cool down. with no thermostat, this doesnt happen it just circulates and warm up to the temp it warms up to and is at the same temp in motor and rad then to hot will come out the overflow, as a resualt, you will wind up losing antifreeze then wont have enough antifreeze in your engine then will damage your engine.Put a thermostat in and a water pump. fix it right or you will damage your car.
Dec 28, 2009 | 1995 Honda Civic
The heater temperature isn't as warm as it use to be. We checked the water and replaced some, but it still isn't heating as good as it should? 240K miles
You may need to find a repair shop with a scanner and can read the coolant temp, if its not at least 195f you will need to replace the thermostat.
Dec 15, 2009 | 2002 Dodge Caravan
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Saeco Classico Espresso Machine Logo
533 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
