Question about Acer AL2017 20" LCD Monitor
I've just had an Acer AL2017 apart that someone left out in the rubbish, assuming that it wouldn't work, i've taken it apart and seems to be ok, nothing burned out no knocks and scrapes. Standby light is flashing green, although screen wont come on, but I assume that I have to connnect it up to an output source, or should a least the basic screen come on anway? any advice?
  • 11,361 Answers
Please look at my pictures of failed monitors, read the guide to understand how monitors work, learn about bad caps, bad solder joints, etc.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL2017%20Abd/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 12, 2010
My monitor had sound and someone playing a game turned it off...I assume as know it it not working. It worked with my other computer and I got a new tower is there a way of getting my sound back,
In the lower r/corner there should e an speaker icon you can mute/unmute and raise/lower volume.
If not, go to Start menu to Programs to Accessories to Entertainment to Volume control, you can adjust yu settings!
Apr 28, 2010 | Acer AL2017 20" LCD Monitor
NO LIGHT ON SRCEEN
This model AL2017 20" Acer monitor is known for having a bad power inverter board. The capacitors go bad, which causes the backlight to completely stop working or flicker intermittently. If you feel like you are electronically and mechanically inclined the board is easily replaced. Search ebay for AL2017 Power Board -- its about 15 bucks plus shipping.
Feb 13, 2010 | Acer AL2017 20" LCD Monitor
My screen stay black, the monitor has power al2017
I called tech support and it was suggested to send the acer AL2017 monitor back to them to make repairs to the circuit board.
Dec 10, 2009 | Acer AL2017 20" LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Mcculloch 484 chainsaw,with manual oil pump that does,nt work
IT GOES IN THE HOLE OF THE SMALL FILTER
THERE IS ENOTHER SMALLER BALL WHITH SPIRG INSIDE THE METAL TUBE THAT HOUSES THE PISTON
BOTH OF THEM WORK AS ONE WAY VALVES
Aug 16, 2009 | Garden
Acer AL2017 has trouble starting up.
I CAN FIX THIS or rather you can there are a total of 5 capacitors in the screen Power Board, that upon inspection the ends are bulging therefore they are bad. So do this: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. I preformed this and my monitor works Outstandingly well with NO problems yea I’m a happy camper.
Jun 07, 2009 | Acer AL2017 20" LCD Monitor
Acer AL2017 Monitor
you will need 3 or 4 ( forget now) 220 uf 25 volt and two 1000 uf 25 volt .... just finished putting this one back together and it's great.
Dec 10, 2008 | Acer AL2017 20" LCD Monitor
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec...
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Oct 14, 2008 | Acer AL2017 20" LCD Monitor
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
