Question about Dell E172FP 17" LCD Flat Panel Monitor
Making use of a computer monitor
Hi!
I was wondering if such a thing existed that would turn a computer monitor (with no computer attached) into a functioning television?
Thanks!
Actually there are a number of very good "external tuners" on ebay. these have vga outputs, a decent tuner, and a video input. I bought 4 of them for $15 each including shipping.
Posted on Jun 25, 2008
  • 91 Answers
I am here to help. Sorry to tell you this but it is not possible because the inputs and outputs from a television and PC are very different.
But is a very good idea!!! Congratulations!
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Posted on Jun 17, 2008
Will not cme on
Hi
Firstly - Is the cabling, mains and data cable, securely attached at both ends and the power turned on at the mains?
Secondly - If so when you press the monitor power button, does a light come on? (often orange coloured) If yes does this change colour when the computer starts its boot sequence? (often to green or blue)?
If no light can be obtained it is likely that the monitor is faulty.
If a light comes up on power up, but doesn't change colour during the computer boot sequence then it is more likely to be the graphics card that is faulty, or sometimes the computer PSU.
The easiest way to find out whether the computer or monitor is at fault is to replace the existing monitor with a monitor that is known to be in full working order, for example from another computer. (Or connecting your monitor to a computer that is known to be working)
Having isolated the faulty component it can be replaced and you should be up and running again.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 18, 2014 | GNR TS902D Monitor
Yellow lines on pc screen
A quick check would be the VGA cable connection to the back of the PC and monitor. Make sure they are snug and completely connected.
Some monitors have the VGA cable attached as a separate item and not built into the monitor. If the 15pin plug becomes loose it will show the problems you're describing.
If that doesn't fix it, Next plug the monitor into a known good PC. If the problem still exists, you have a bad monitor...If the monitor works fine on the known good PC, the Video Card/Onboard video interface is bad and will need to be replaced.
Nov 29, 2013 | Computers & Internet
I was wondering if there any way to hook external monitor to this computer
Hi singingstar4 !
You havent specified to which computer.
Almost all computers (PCs, laptops) have external VGA, HDMI, or DVI connections.
Most chances are that one exists on your computer too. Just search for it.
Best of luck,
omerk.
Jan 29, 2011 | Computers & Internet
Acer AL1923 monitor attached to Macbook Pro with HDMI. Works, but goes blank for 20 - 30 seconds or so every now and then. Can't find a Pac driver for it. Does one exist?
this is a problem sometimes with hdmi. it also happens with dvd players. try to do a cold reboot of your laptop and see if that helps. also before turning of your laptop do the same with your monitor. turn it off, wait a few seconds, then turn it on. after that turn your laptop on.
Jun 21, 2010 | Computers & Internet
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
Monitor
Hi there
if your monitor came with a cd rom use it if not you need to be sure that the monuitor is compatable with the pc also check the pins at the end of the monitor cable to be sure that they are not bent. also you can make sure that the monitor is working by trying to attach it to a nother computer and see what happens please keep me posted on this there is still a few things we can try to do ok
best regards mike
Mar 08, 2009 | HP w2207 Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
GPS LG790
The manual is all on disk. I have this model and attached the remote with little problems. One caution is to make sure the screws are in tightly as they are very short.
Dec 26, 2007 | LG 790SC (White) 17 in.CRT Conventional...
Monitor not working...sorta
I just changed my video card and after turning up my screen refresh rate (Hz) my monitor started doing the same thing. Monitor worked great for a long time but now its done! The only thing I can think of is that it has to have 60Hz, turn it up for gaming and its too sensitive to frequency. By the way, mine will turn on after a few power cycles.
Dec 01, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag LT561 Lcd monitor
Simply try replacing ALL the large Value Electrolytic Capacitors on that board, 1000uF, 470uF, 330uF, 220uF, they are "the big fat round blue things" marked with say 1000uF 16Volt or the like, get the EXACT same ones and replace them... this may indeed fix ya uint. Good luck.
Jul 07, 2007 | Mag Innovision LT561D PNP Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
Alun Cox
