Question about HP Compaq nx9600 Notebook
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and someone gave me a solution but I did not print and keep it. Can anyone help?
  • HP Master
  • 7,733 Answers
Information. HP Compaq notebook will not boot up.  It seems to - hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced BooHP Compaq notebook will not boot up. It seems to - hpweb_1-2_plus.gifcreen, select Safe Mode anHP Compaq notebook will not boot up. It seems to - hpweb_1-2_minus.gif. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
Posted on Nov 11, 2010
  • lamary9 Nov 12, 2010
    The solution would be very helpful if I could get that either of the stages. The notebook will not run long enough to start up at all. It turns on, then off immediately and keeps trying to start up.
  • Doctor PC
    Doctor PC Nov 12, 2010
    Ok you then will need a system restore boot disk.Here is the link for most windows oshttp://h20000.www2.hp.com/bizsupport/Tec...
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | HP Compaq nc6000 Notebook
HELLO , I HAVE A HP COMPAQ NX 5000 AND IT DIDN'T START. IT START VERY HARD, DID YOU CAN TELL ME WHAT'S THE PROBLEM ? THANKS A LOT !
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx5000 Notebook
How to removed the bios administrator password
remove the battery and power supply, open it, and take the cmos battery out. wait 3 minuts. boot it without the cmos, it will say password disabled. shut it down and put it back together. you're done!
Feb 02, 2011 | HP Compaq Business Notebook 2230s
I have a refurb'd hp compaq 7100 - it will not boot up - begins bootup protocol and immediate shuts down - orange light begins flashing and it beeps. Will not start with a boot CD. What is going wrong?
The processor is probably getting too hot. If it's refurbished, it is likely that an unexperienced technician put it together without removing and re-applying the heat silicone compound on the processor and heat exchanger. It will shut down if the temperature reaches the threshold level the BIOS senses.
Nov 25, 2010 | Computers & Internet
My compaq F756NR's screen remains blank after booting up. The power buttons are on. Please help.
Remove the battery and the power plug. Restart the laptop without the battery and just the power plug. This may help. If it does shut back down and put the battery back in. If it doesn't, then please contact the vendor or a local technician. Cheers, Ravi Shanghavi
Aug 18, 2010 | HP Compaq Presario F756NR Notebook
My laptop dont read hard disk drive
Okay, shut down your laptop, turn it up side down, remove laptop battery, remove Cd drive by first unscrewing the CD drive's screw before removing/detaching the Cd drive from the computer.
Turn on your computer without the Cd/drive, allow computer to boot, after a while, shut down computer, fix in back the CD drive and turn the system back on.
By now the system should read the CD drive. If it does not, then I'm afraid some this is wrong with the Drive, but I'm sure it should work.
Take care.
Apr 14, 2010 | HP Compaq Presario C500t Notebook
HP Pavilion DV2700T PC Notebook - won't reboot.
go into bios next time it starts and turn off all power settings, same in control panel in windows and turn off sleepmode and hibernate.
Dec 01, 2009 | HP Pavilion DV2700T PC Notebook
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
HP Compaq nx9600 Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
