Question about Frigidaire ATF6000ES Front Load Washer
I moved my front loading washer over a little, it's level, I checked. But evey load big or small gets out of balance and the washer shakes the whole house. What to do? Signed, Despert
  • Frigidaire Master
  • 5,568 Answers
Moving the washer may have caused one of the adjustable feet to turn so that is no longer in contact with the floor.
Take a thin, stiff piece of cardboard (such as the back of a paper pad) and try shoving it under each corner. You may find one clear of the floor that will need some minor adjustment to sit firmly again.
Posted on Nov 11, 2010
This front load washer is unbalanced all the time and shakes the whole house. Is it worth it to fix it?
Yes of course it may simply be a balnce problem, the legs need to be re adjusted. I use a level to check the balance. adjusting each leg accordingly, another thing it might be is that the counter weights balance rods are needing replacing or re greasing with lithium bases greased
Apr 11, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Exterior cabnet shakes very bad when in spin cycle ((FWTR445RF
this can happen for a few reasons. the first being overload of the washer with to much wash items, the second being the washer is not sitting level on the floor. u can use a small level and level from side to side and from front to back using the adjusting feet on bottom of washer. also could be that the load of wash is not balanced in the tub. This happens more on a top load washer than a front load. hope this helps
Apr 15, 2014 | Washing Machines
The washer gets unbalanced on small loads that never happaned before a couple of weeks ago. The machine has a unbalance spin load compensator but makes ungodly banging now, that's never happen until...
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Mar 08, 2011 | Maytag MAV5920E Top Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
SHAKING WASHER
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
Aug 21, 2009 | LG Washing Machines
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Jan 12, 2008 | LG WM2277H Front Load Washer
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
