Question about Kodak EasyShare M1033 Digital Camera
Battery fully charged but when camera switched on, it swtches off after few seconds.lens fail to retract.?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 11, 2010
Camera retracts it's lens and turns itself off about 10 seconds after I turn it on
Have you fully charged the battery? if it is a new camera or battery,it needs at least 12 hrs of charge,to maintain good charge, if only a short time of charge was given from new the life of the battery will be greatly re-juiced,try a new battery with a full charge, if this fails your camera is probably faulty, take it back to get a replacement.
Sep 07, 2014 | Olympus FE-210 Digital Camera
The zoom lens is stuck in the out psition and won't retract!
Risky method!
Switch off, replace fully charged batteries, grab the inner-most tube (smallest) of the lens assembly and gently pull outward. Keep your grip and power on the camera. There should be some vibrations from the motor. Let go your grip and see if the lens retracts to its housing.
If that fails, take it in for a repair.
Aug 20, 2014 | Cameras
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Olympus X-920 camera lens fails to fully open when powering on, the lens cover does open for a few seconds, then the lens retracts and opens again every few seconds. The Battery appears to be fully...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jul 02, 2011 | Olympus X920 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
The lens won't retract
If the lens is stuck out extended you may want to call Olympus Customer Service to discuss repair process and pricing. If the battery is fully charged and the lens still stays extended then this is a clear repair issue as something in the lens assembly has failed. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 30, 2008 | Olympus Stylus 710 Digital Camera
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
