Question about RELIANCE ELECTRIC WATER HEATER
The temp./pressure valve on top of the heater is leaking. what is the cause and solution.
    Genius:
  • 1,015 Answers
It is possile that it had apressure fluction for various reasons. It's also possible that valve spring is just getting weak. What i would do first is replace T&P valve and see what happens.These are common 3/4 inch male iron pipe t&p valve available at most hardware stores. First shut off water supply to water heater, then open valve on hot water side of nearest faucet to relieve pressure. Remove old valve by turning counterclockwise. You may need a pipe wrench as they can be pretty tight. Remove old t&p valve and use teflon pipe tape or joint compound on new valve threads. Install new valve and tighten securely. Close faucet previously opened to relieve pressure,then turn water supply valve to water heater. Check for leaks and tighten further if needed. Check valve occasionally for next couple days. If no further leaks from valve then your're in business. Hope this helps. Thanks
Posted on Nov 11, 2010
Natural gas water heater pop off valve leaking even after replacement
This is unusual. The first thing to ask is what is the water pressure reading at your location? It could be too high. That would cause the valve to be close to opening and leak. The second could be something to do with the thread area that the valve screws into. What is the age of the heater and has it ever been dropped or damaged? Third is how hot is the water temp?
Jul 18, 2017 | Water Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
    The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
    The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
    Dec 09, 2010 | Whirlpool Water Heaters
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Pressure relief valve
    The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
    Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Water is running out of the vale outside
    Your temp and pressure valve is leaking, one of two problems is causing this. Either you need to install/ replace the pressure reducing valve between your house and the city water main(well), or you need to check the thermostat to be sure it is not overheating. Whatever you do DO NOT plug, cap, or block the t&p valve ever. Doing this is a bad idea, and could be fatal.
    Feb 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
    My water heater has a bit of water from the top is(very small amo
    thats normall it just lets of presure when needed which will cause a little water
    Dec 30, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
    Hot water not very hot..also seems low in pressure
    pressure temp valve leaking
    tank leaking
    hot water line leaking
    shut off water to tank and leave sit for 4 hours turn on water tap and test temp if hot you have a leak
    Oct 17, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    Hot water heater leaking at the top valvue
    If it is your pop off valve (also known as a temp and pressure valve) it will most likely be due to a over pressure situation, whether it is due to excessive temp, or high street pressure, I'm not sure.  There is also usually a vacuum breaker on the cold side of the hot water tank, this will on occasion spit out a little water, but unless it is defective, it should never be so much as that you would notice a "leak".
    Another thing, if it is the T & P Valve, there should be no shut off installed on the piping.  There should be a pipe that terminates with 18" of the floor, and it is not normal for this valve to discharge unless there is a problem with the temp or the pressure inside the tank.
    Hope this helps
    Jan 07, 2009 | Water Heaters
    RELIANCE ELECTRIC WATER HEATER Logo
    144 people viewed this question
    Top Reliance Water Heaters Experts
    Mack Baxter
    Gil Shultz
    rickb63
    Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
