Question about GE GSH25JFR Side by Side Refrigerator
Help My refrigerator started making a clicking noise like tha fan was trying to start but wouldn't. When i hold the water dispenser in the noise stops but no water comes out. The next day the refrigetator and freezer stopped cooling. Still getting power and lights come on but making a clicking noise and not cooling
Well mine went through some of the same thing the fridge put out less and less cold ait and the freezer started to thaw just a tad on max settings. Mines about 8 years old and a kenmore.
Made the decision on an opportune time when Sears was having an additional 10% off sale..... my problem will be fixed ina bout 2 hours when my new fridge is delivered. The sad truth is (I now its cliche) they don't make um like they used to. Last fridge i had lasted nearly 20 years. Now if you get more than 5 out of an appliance you're doing good. Good luck but it sounds like the compressor died. You'll either need an expert to come out (think they have a min fee of $100 or more) or repalce it.
Posted on Aug 19, 2008
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a Hot Point HSM25GFRF SA refrigerator, first the ice maker / water stopped working then the the refrigerator started making a clicking noise and every time it clicks the fsn does one rotation then...
I have the exact same problem.
It stopped dispensing water and ice, then it started to make a clicking noise and now the freezer and the refrigerator don't work.
It's interesting that this failure occurred 3 months after the 5 year warranty expiration.
Apr 13, 2010 | Hotpoint Refrigerators
The unit stopped dispensing water, makes clicking nose
If you would like to do this yourself and save the fee of a service tech I ill tell you the motherboard and compressor start components have been affected. Just replacing the board is not always the answer. These refrigerators are sensitive to electrical surge, fan failure, compressor start component failure and eliminating the cause is the best and less expensive way to approach this, I will return later and discuss parts and I do need you to confirm your model is the GSH25JFR, Thanks, Sea Breeze
Feb 08, 2010 | GE GSH25JFR Side by Side Refrigerator
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
