Question about Royal VF1700MX Shredder
Royal VF1700MX Shredder Shredder runs in reverse but won't run forward. Not manually pushing forward button or in auto mode. Cutters are clear, gears appear to be OK. Runs fine backwards but not forward. Any ideas
    Genius:
  • 1,218 Answers
Sounds like you've either lost the "eyes" or the pcb inside...contact Royal at 1-800-524-0799 for parts assistance.
Posted on Nov 19, 2010
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Royal 15MX shredder does not run at all in auto mode. Runs fine in reverse.
There is most likely something blocking your shred gears preventing it from running in forward motion. If you press the feed button will it engage the motor? If not, you will need to have it serviced if you cannot visibly see any blockage. Be sure to unplug this unit before attempting to clear the pathway.
Mar 13, 2011 | Royal 15MX Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
My RL170MX will only run in reverse mode. Forward and auto modes do not work. What controls the motor rotation ?
Motor forwards rotation is begun by inserting paper in betwen the 2 "eyes" in the paper throat of the shredder. They can become dusty/dirty and not function, if they are clean and yet the motor still will not turn in the forward direction it is possible the pcb inside the unit is faulty...contact Royal at 1-800-524-0799 for parts assistance.
Nov 12, 2010 | Royal RL170MX Shredder
Royal VF1700MX - motor does not turn
You've probably lost the pcb inside the machine. Give Royal a call at 1-800-524-0799 they'll be able to advise on part number and price.
May 21, 2010 | Royal VF1700MX Shredder
VF1000MX Shredder: Shredder works briefly in reverse, but won't run f...
Try cleaning the "eyes"....if they get dirty they can act erraticaly...if that dosn't fix it you may have a pcb prob....you can give Royal a call at 1-800-524-0799 for parts information and advice.
May 16, 2010 | Royal VF1000MX Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Sep 15, 2009 | Royal 15MX Shredder
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
Royal VF1700MX  Shredder Logo
506 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
