Question about AT&T Partner 18 Phone (315805B)
Noise in system
15 Year old Partner Plus system. The system is leaking noise into one of the outgoing lines (MLS-18D) whenever there is an incoming call to the main switchboard (MLS-34D). We have replaced the phone lines to the office but got no improvement. Suspect the problem is either in the 34D or in a module. Suggestions
  • 10 Answers
Probably in the module. Switch to different port on module and see if it clears the problem
Posted on Sep 03, 2009
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
Phone static on the partner 18d
Is it on the same line? What about when you call other extensions, is there static?
If it is a line, swap that line and another. If you have static on the same line port, then it is a port problem of the system. If it follows the dialtone, the line from the phone company is the problem.
Jan 14, 2010 | Avaya Partner 18 Eurostyle 18D telephone
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
We have an AT&T system with 4 lines and several MLS-12D phones. Two of our 4 lines are not working. If someone is on the main line, additional incoming calls do not roll over to the other lines. This...
Changing programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#301"
the display should say line assignment and station:
enter in the station you want to program the line on.
the display will then ask for the line number to program
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say Lxx and 2 not assigned
enter 1 on the dialpad (assigned)
repeat procedure for remaining sets
enter feature "00" when finished
Sep 01, 2009 | AT&T Lucent MLS-12D Phone
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
Need to reset Time/Day on it
This should do ya.
May 18, 2009 | Avaya MLS 18D Corded Phone
MLS-12d phone system
Your system is actually called Partner.
Compatible phones will consist of MLS12, MLS12D(display),Mls18, 18D(caller id display), 6D(display), 34, 34D(display) No other phone will work on this system
To program phone numbers
Press Feature 00, press/select a buton to program, input speed dial number. Press Feature 00 again.
Mar 22, 2009 | AT&T Lucent MLS-12D Phone
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
No light, no incoming and outgoing calls
Assuming you got this fixed. If not please repost.
Oct 06, 2008 | Lucent PARTNER18 Corded Phone
AT&T Partner 18 Phone (315805B) Logo
124 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
